Temperature and flux continuity across interphase.
Hi all,
I am working on non equilibrium thermal model in Ansys Fluent. It has fluid as well solid porous zones superimposed over each other. Both the zones are adjacent to a solid wall which is subjected to a heat flux boundary condition. I have created a non-conformal mesh and manually created an interface between wall, porous solid and porous fluid walls. The flux continuity has been maintained by fluent by I want the temperature at the interface for each of the boundaries to be the same too. How can I achieve this? Thanks in advance. |
did you figure it out? if yes can you please help. Thanks. |
