jps115 |
February 17, 2022 04:11 |
Deposition flux for particles in an Eulerian model
Hallo everyone,
I am a Master student in Transport Phenomena and for my thesis I am modeling the human respiratory system. In my thesis I am comparing lagrangian and Eulerian models for particle tracking.
I am trying to write a UDF that adds a Deposition flux for particles near the wall of my geometry in an Eulerian model.
I do this by first writing a DEFINE_ON_DEMAND udf that sets a UDMI to 0 for cells in my fluid and 1 to cells near the wall.
I then write a DEFINE_SOURCE udf that uses this UDMI value to see when to implement the flux. The UDF both compile and load with out error. But after the first iteration FLUENT crashes. I have atteched my code below.
The equation I am trying to implement is as follows:
Where is the convective velocity
If someone can help me out finding my mistake or can help me find a better approach to implement this flux it would be really appreciated.
#include "udf.h"
#include "flow.h"
#include "dpm.h"
#include "mem.h"
#include "sg.h"
#include "metric.h"
DEFINE_ON_DEMAND(selecting_the_cells)
#if !RP_HOST
real A[ND_ND];
Domain *d;
Thread *t, *tc, *t0;
face_t f;
cell_t c, c0;
int Zone_ID = 13; /* Zone Id can be seen in the Boundary Conditions Panel, for me 13 = Wall */
d=Get_Domain(1);
tc=Lookup_Thread(d, Zone_ID); /* thread pointer of the wall */
/* Loop through all the cell threads in the domain */
thread_loop_c(t,d)
/* Loop through the cells in each cell thread */
begin_c_loop(c,t)
C_UDMI(c,t,0)=0;
C_UDMI(c,t,1)=0;
C_UDMI(c,t,2)=0;
C_UDMI(c,t,3)=0;
end_c_loop(c,t)
begin_f_loop(f,tc)
/* c0 and t0 identify the adjacent cell */
c0=F_C0(f,tc);
t0=THREAD_T0(tc);
/* this loops over all cells adjacent to wall and lets the UDM = 1.0 */
C_UDMI(c0,t0,0)=1.0;
F_AREA(A,f,tc);
C_UDMI(c0,t0,1)=A[0];
C_UDMI(c0,t0,2)=A[1];
C_UDMI(c0,t0,3)=A[2];
end_f_loop(f,tc)
#endif
Message("done with ON_DEMAND");
DEFINE_SOURCE(deposition_source, c, t, dS, eqn)
real source;
real NV_VEC(v_c_vec);/* declaring vectors v_c_vec*/
real NV_VEC(v_grad_v); /* declaring v*gradv as vector */
real NV_VEC(diff); /* declaring diff as vector */
real NV_VEC(psi_vec);/* declaring vectors psi */
real NV_VEC(M_gravity); /* declaring vectors gravity*/
real conv_flux, dif_flux;/* declaring value flux */
real NV_VEC(A1), NV_VEC(A3); /* declaring vectors A */
real grad_vel[3][3]; /* declaring array grad vel */
real vel[3]; /* declaring array vel */
float Um = 1.279279;/* Mean velocity at inlet m/s */
float d1 = 0.006; /* Diameter of parent tube in m */
float rho_p = 3413; /* density particle kg/m3 */
double visc_f = 1.82e-5; /* kinematic viscosity */
double d_p = 7.35e-6; /* particle diamter in m */
double D = 1e-12; /* Mass Diffusivity m2/s (Stokes–Einstein equation) */
NV_D(M_gravity, =, 0.0, 0.0, 9.81);
real gravity = NV_MAG(M_gravity); /* M_gravity is the gravity vector M_gravity[0] = 0, M_gravity[1] = 0, M_gravity[2] = 9.81 */
real St, Fr, Fr_inv, Pe, Pe_inv , A2[3], conc;
St = rho_p*pow(d_p, 2)*Um/(18*visc_f*d1);
Fr = pow(Um, 2)*gravity*d1;
Pe = d1*Um/D;
Pe_inv = pow(Pe, -1);
Fr_inv = pow(Fr, -1);
int i, j;
conc = C_YI(c, t, 0) * rho_p;
grad_vel[0][0] = C_DUDX(c, t), grad_vel[1][0] = C_DVDX(c, t), grad_vel[2][0] = C_DWDX(c, t);
grad_vel[0][1] = C_DUDY(c, t), grad_vel[1][1] = C_DVDY(c, t), grad_vel[2][1] = C_DWDY(c, t);
grad_vel[0][2] = C_DUDZ(c, t), grad_vel[1][2] = C_DVDZ(c, t), grad_vel[2][2] = C_DWDZ(c, t);
vel[0] = C_U(c, t), vel[1] = C_V(c, t), vel[2] = C_W(c, t);
NV_D(psi_vec, =, C_U(c,t),C_V(c,t),C_W(c,t)); /* defining psi in terms of velocity field */
NV_V(A1, =, M_gravity);
NV_S(A1, *=, Fr_inv);
/* calculating vector matrix multiplication */
for ( i = 0; i < 3; i++ )
A2[i] = 0;
for ( j = 0; j < 3; j++ )
A2[i] += grad_vel[i][j] * vel[j];
NV_D(A3, =, C_UDMI(c, t, 1), C_UDMI(c, t, 2), C_UDMI(c, t, 3));
if (C_UDMI(c,t,0)>0.)
NV_D(v_grad_v, =, A2[0], A2[1], A2[2]); /* defining v_grad_v */
NV_VS_VS(diff, =, A1, *, St, -, v_grad_v, *, St);
NV_VV(v_c_vec, =, psi_vec, +, diff);
NV_S(v_c_vec, *=, conc);
conv_flux = NV_DOT(v_c_vec, A3);
dif_flux = -Pe_inv*NV_DOT(C_YI_G(c,t,0), A3);
C_UDMI(c, t, 4) += conv_flux + dif_flux;
source = conv_flux + dif_flux;
dS[eqn]= 0;
else
C_UDMI(c, t, 4) = 0;
source= 0;
dS[eqn]=0.;
return source;
