UDF 3D mesh two movements example
Greetings everyone I´m trying to make a simple exmaple of UDF with a 3D volume, The exmaple basically consist in an sphere that follows an sinusoidal function on the Y axes and spining on its own axes with determinate angular speed, what I tried was to put a UDF function on the wall of the object and its surrounding mesh, enable dynamic mesh for the control volume and a spining rotation for the surroundings of the sphere, obviously when I ran it failed , this is the code that I tried to run:
/* Moving grid problem -CG movement of a box*/ #include "udf.h" static real velx = 0.0; DEFINE_CG_MOTION(box, dt, vel, omega, time, dtime) { NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); velx = 0.05 * sin(3.1415927 * time / 10.); vel[1] = velx; Message("Time=%f, vel[1]=%f/n", time, vel[1]); } Somtimes it shows that the dynamic mesh produces a zero-volume, other times it generates other errors and sometimes it moves all the domain I will really appreciate your help guys |
