UDF for power law viscosity Received signal SIGSEGV
Hi guys,
I‘m using FLUENT 20.0 to do a simulation with non-Newton fluid governed by a power law. the udf code was as follows. =============================================== #include "udf.h" DEFINE_PROPERTY(non_newtonian_viscosity,cell,threa d) { real viscosity; real stress; real visc_min=1; real visc_max=18; real stress_min=0.1; real stress_max=100001; real n=0.15; real k=2.52; stress= C_STRAIN_RATE_MAG(cell,thread); if (stress>=stress_max) { viscosity=visc_min; } else if (stress<=stress_min) { viscosity=visc_max; } else if ((stress>stress_min)&&(stress<stress_max)) { viscosity=k*pow(stress,n-1); } return viscosity; } =============================================== The udf could work in fluent,but an error is reported after 2k iterations. Reversed flow on 7 faces of pressure-outlet 16. ! 2706 solution is converged 2706 3.0994e-04 2.7519e-04 1.9778e-04 9.7265e-05 2.6660e-04 1.4593e-04 0:00:28 18 ================================================== ============================ Node 10: Process 18148: Received signal SIGSEGV. ================================================== ============================ 999999: mpt_accept: error: accept failed: No error 999999: mpt_accept: error: accept failed: No error 999999: mpt_accept: error: accept failed: No error 999999: mpt_accept: error: accept failed: No error 999999: mpt_accept: error: accept failed: No error 999999: mpt_accept: error: accept failed: No error Can anyone give me some advise, I have no idea what to do.. Thank you very much. |
