Get the mole fraction in UDS and UDF Error "the fl process could not be started"
2 Attachment(s)
I am working on particle-resolved fixed bed and using the UDS to calculate the reaction species in catalysts(represented as solid phase in Fluent), so I need to calculate the diffusion coefficient of species using the macro DEFINE_DIFFUSIVIT(name,c,t,i) and the formula in the attached picture.
I set uds to work in all zones ,so I wrote the codes for the diffusion coefficients in the solid phase and in the liquid phase separately, where the code for the liquid phase is a simplification of the code for the solid phase, you can see the code for the solid phase here. #Codes #include "udf.h" /*[O2,CO2,C2H4,C2H4O,H2O,N2]*/ real M[6]={32,44.01,28.06,44.052,18.015,28.013};/*these are the relative molecular mass of the species i */ real V[6]={16.6,26.9,41.04,28.85,12.7,17.9};/* these are the sum of the atomic diffusion volumes for species i*/ #define species 6 #define R 8.314 #define d_pore 20e-9 #define epslon 0.4 #define tao 2 DEFINE_DIFFUSIVITY(uds_diff_solid,c,t,i)/*to calculate the diffusivity of the species i in the solid phase*/ { real temp=C_T(c,t);/*get temp in the solid phase*/ real press=C_P(c,t);/*get tpressure in the solid phase*/ real density=C_R(c,t);/*get density in the solid phase*/ real D1=0.;/*calculate the binary diffusion corffcient*/ real Df=0.;/*calculate the molecular diffusivity*/ real Ds=0.;/*to get the the effective diffusivity of the ith species in the solid phase*/ real Dk=0.;/*calculate the Knudsen diffusivity of the species i*/ real Mm=0.; real Mm_total=0.; real mole_fraction[6]; int x=i; int y; for(y=0;y<species;++y) { Mm = Mm + C_UDSI(c,t,y)/M[y];/*use C_UDSI(c,t,i) to get the mass fraction of ith species in solid phase*/ } Mm_total =1/Mm; /*calculate the average relative molecular mass*/ for(y=0;y<species;++y) { mole_fraction[y]=C_UDSI(c,t,y)/(M[y]/Mm_total); }/*get the mole fraction of ith species in solid phase*/ for (y=0;y<species;++y) { if(y!=x) { D1=D1+(mole_fraction[y]/(1e-3*pow(temp,1.75)*pow((1/M[x]+1/M[y]),0.5))/(press*pow((pow(V[x],1/3)+pow(V[y],1/3)),2))); } } Df=(1-mole_fraction[x])/D1;/*get the molecular diffusivity, if I need the diffusity of ith species in fluid phase, I will return Df*density */ Dk=48.5*d_pore*pow((temp/M[x]),0.5);/*get the Knudsen diffusivity of the species i*/ Ds=epslon/tao*pow((1/Df+1/Dk),-1);/*get the the effective diffusivity of the ith species in the solid phase*/ return Ds*density;/*the uds needs diffusivity*density, so I return this*/ } Problems 1. All UDF have been able to compling and load them sucessfully. However, on trying to run the simulation after incorporating those UDF, I am constantly facing an error "The fl process could not be started". 2. I can only get the mass fraction of the ith species by the uds in Fluent, but I have to use the mole fraction to calculate the diffusivity, so I use the method in the attached picture, is there a better solution? 3. As you can see, I have to calculate the mole fraction every time when I want to get the diffusivity of all species , is there a better solution? I am unable to figure out the exact problem, and would highly appreciate any sort of help. Thanks in advance. |
I have solved the above problem, just modify D1 in the code as follows:
D1 = (1e-3*pow(temp,1.75)*pow((1/M[x]+1/M[y]),0.5))/(press*pow((pow(V[x],1/3)+pow(V[y],1/3)),2)); D2 = mole_fraction[y]/D1; D3 = D3+D2; But I have encountered a new problem now. Solid zones don't provide a pressure term, so I set the pressure constant, it can be calculated. In the fluid zones I need the actual pressure to calculate, so I set pressure=C_P(c,t), but this causes divergence. |
