UDF for 3D Dissolved Oxygen Model
Hello everyone,
I'm currently trying to do a 3D transient simulation to determine dissolved oxygen concentration in a pond. I'm using an impeller to create circulation in the pond. There are two cell zone, one is a rotating body containing the impeller and the other one is a stationary body containing the rest of the pond. https://i.postimg.cc/Z5R2ZWfx/Screen...-30-130231.png I'm using UDF to model the dissolved oxygen. The UDF is as follows: #include "udf.h" #define Cs 0.0085 #define C_initial 0.003 #define a 22.34 DEFINE_SOURCE(mass_source1, c, t, dS, eqn) { real S, C; real time = CURRENT_TIME; S = a * (Cs - C_initial); S *= exp(-0.1 * time); C = C_initial + (Cs - C_initial) * (1 - exp(-a * time)); if (C >= Cs) { C = Cs; S = 0.0; } C_UDSI(c, t, 0) = C; dS[eqn] = 0.0; return S; } I've added this to the Mass source term in both fluid zones https://i.postimg.cc/VN0hr3PS/2.png https://i.postimg.cc/NjzV0QSq/3.png After running the simulation, the results I obtained indicated that the dissolved oxygen model did not follow the flow of water in the pond. Instead, it radiated from the rotating body very slowly. Velocity contour: https://i.postimg.cc/pTD1kzTR/Whats-...t-13-16-21.jpg Dissolved oxygen contour: https://i.postimg.cc/tT0Mh29B/Whats-...t-13-16-18.jpg I've looked into the mass source term documentation and it says the mass will be accelerated by the flow. What I want is for the dissolved oxygen to follow the flow of the water so I can find out the effects of different types of impellers to the dissolved oxygen concentration in the pond. What am I doing wrong here? Is my UDF wrong or do I need to add something else? As I am new to Ansys and UDF, any pointer or help would be highly appreciated. Thank you |
