[Sponsors] | |||||
Alex Tarantul
Rep Power: 3 ![]() |
When working with Ansys Fluent + MHD module, Electric potential: is it possible to define the electrical conductivity (in fluid domain) in such a way that in the most of domain it is a function of temperature but in some specified region it has some constant value REGARDLESS of temperature?
Rodrigo Villarreal
Rep Power: 11 ![]() |
Maybe you can create the corresponding zone from the geometry, and then use a define_adjust udf to set the constant value of the conductivity
| Tags |
| electrical conductivity, material properties, mhd module, udf |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [snappyHexMesh] No layer in corners and high skewness | Lukas1 | OpenFOAM Meshing & Mesh Conversion | 1 | May 23, 2023 11:40 |
| [snappyHexMesh] No generation of layer onto zerothickness surface | crubio.abujas | OpenFOAM Meshing & Mesh Conversion | 3 | October 25, 2022 04:20 |
| [snappyHexMesh] Prism layer collapsing in refinement transition | rubenparedes | OpenFOAM Meshing & Mesh Conversion | 8 | May 13, 2021 11:55 |
| [snappyHexMesh] layer not added | Rasmusiwersen | OpenFOAM Meshing & Mesh Conversion | 1 | January 2, 2020 10:43 |
| [snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 14:47 |
