ANSYS UDF on GPU
Like Tree1Likes
  • 1 Post By plotr
Old   March 3, 2025, 10:54
Default ANSYS UDF on GPU
plotr is on a distinguished road
Hi there,
So, currently, we are running some PyFluent simulations on an HPC platform, but to speed up our computations vastly, we would like to use GPU instead of CPU.
We have the following UDF to generate a parabolic time-dependent velocity at the inlet:
/* UDF for time-dependent coronary inflow with a paraboloid inflow profile
Units according to SI Standards */
#include "udf.h"
#define a 0.0015 /* radius inlet in m */
#define bpm 65.0
#define pi 3.141592654
DEFINE_PROFILE(inlet_velocity,thread,position)
/* "Parallelized" Sections */
#if PARALLEL
face_t f;
double Va; /* Velocity profile */
double t; /* transient flow time/phase in cycle */
double r; /* radius */
double Qt; /* Flow profile */
double Iv; /* Shape(function) of velocity profile */
int ncf = 20;
/* Fourier coefficients describing transient velocity profile */
double FC[20][2] = {
{7.771158879065718e-07, 0.0},
{-1.9137987527226527e-07, -1.791911369679127e-09},
{1.0845217682621154e-08, -8.480206194017801e-08},
{1.7684953869140035e-08, -1.7029291957063344e-08},
{2.137056864166352e-08, -2.3711687251689842e-08},
{3.626328105441136e-08, 5.085415716967635e-09},
{1.1312674519145852e-08, 2.563164635736455e-08},
{-7.96671055698641e-09, 1.5020549999536426e-08},
{-8.326548245953747e-09, 2.9831718662924694e-09},
{-4.124528495204487e-09, -2.3493417624601775e-10},
{-3.538249905026171e-09, -8.004106638204953e-11},
{-3.8635323280883435e-09, -2.88857991468041e-09},
{2.480966807062465e-10, -5.23914605261328e-09},
{3.997335176893913e-09, -2.07716227670381e-09},
{2.64013476254159e-09, 1.4056024177653453e-09},
{7.079805292876343e-10, 1.167137448080335e-09},
{1.2368603689937795e-09, 1.0370616260206528e-09},
{2.3038933499127694e-10, 2.8560702934490556e-09},
{-2.773198988875632e-09, 1.7076844087473355e-09},
{-2.137746293389916e-09, -1.4757223448181385e-09},
t = (CURRENT_TIME * (bpm / 60.0) - floor(CURRENT_TIME * (bpm / 60.0))) / (bpm / 60.0); /*t is the local time within each period*/
Message("CURRENT_TIME = %g, t = %g\n", CURRENT_TIME, t);
begin_f_loop(f, thread)
double w0 = (2.0 * pi) / (60.0 / bpm);
int i;
float x[ND_ND];
float xx, yy, zz;
F_CENTROID(x,f,thread);
xx = x[0]; /* x-coordinate */
yy = x[1]; /* y-coordinate */
zz = x[2]; /* z-coordinate */
r = sqrt((xx*xx) + (yy*yy) + (zz*zz)); /* Distance to centroid */
Qt = FC[0][0];
for (i = 1 ; i <= (ncf - 1) ; i++)
Qt = Qt + FC[i][0] * cos(i * w0 * t) + FC[i][1] * sin(i * w0 * t);
Iv = (1. - pow(r,2)/(a*a));
Va = (2.0 * Qt)/(pi*(a*a));
Message("Va = %g\n", Va);
F_PROFILE(f,thread,position) = (Va * Iv);
end_f_loop(f,thread);
#endif /* !RP_HOST */
The problem here is that when we switch to GPU, the inlet boundary condition is no longer a time-dependent value but becomes the same value (the mean value of our Fourier series) throughout the entire simulations. I am assuming the time is not processed correctly within the UDF anymore due to using GPUs instead of CPUs. Still, I cannot find any (recent) information about the compatibility of ANSYS Fluent on GPU with UDFs.
Has anyone encountered a similar problem? If anyone has tips to solve this, please let us know. Thanks in advance!
Milan2013 likes this.
plotr is offline   Reply With Quote
Old   March 7, 2025, 07:22
Default Python UDF
Update: I started working with Python UDFs and discovered that they are currently the only UDFs that support GPU computing. However, since Python UDFs are still in beta, there is limited documentation and support available. Additionally, the examples provided did not produce the expected results. If anyone has further insights or resources on using these UDFs, please let me know.
Old   March 14, 2025, 11:20
Hector Maldonado
DigiHctrGT is on a distinguished road
I was confronted with a similar situation. I asked in the Ansys Forum and a representative told me that some developments are going on to expand the capabilities of the GPU-based solver. So, as far as I know, there is no alternative. You could check if a named expression (with some limitations) might suit your purposes.
DigiHctrGT is offline   Reply With Quote
cpu, fluent, gpu, inlet bc, udf
Ansys Installation on Docker Container mohsen.shiea ANSYS 11 March 14, 2024 12:18
Radially varying heatflux UDF - Ansys Fluent farhanjaved Fluent UDF and Scheme Programming 1 October 25, 2020 03:38
UDF for coding CFD ANSYS FLUENT zuraidah rasep FLUENT 2 September 5, 2020 23:22
Error in UDF calling parameters from ANSYS WorkBench anand32 Fluent UDF and Scheme Programming 0 April 6, 2018 20:52
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
