Define bubble diameter UDF
Old   March 14, 2025, 10:24
Default Define bubble diameter UDF
Hector Maldonado
DigiHctrGT is on a distinguished road
Hi all,
I'm trying to set a UDF to set the bubble diameter for an Eulerian simulation while simulating the turbulence under the Dispersed model (as the density ratio is way beyond 1).
While a similar UDF works perfectly for the Mixture model (for turbulence), it does not work with the modifications I've deemed necessary (i.e., pointing to the liquid-primary phase thread using the super_thread macro, as suggested in another thread from this Forum).
The previous formulation resulted in SIGSEV error.
I managed to solve the issue:
1. Mixture and liquid threads need to be defined,
2. Mixture is pointed by using the THREAD_SUPER_THREAD(t) macro
3. Liquid phase is pointed by using the conventional THREAD_SUB_THREAD(mix, 0) - 0 because that's the ID of the continuous phase.
Thus, the UDF looks like:
#include "udf.h"
#include "math.h"
Thread *mix; /* Define the mixture thread */
Thread *liq; /* Define the liquid thread */
DEFINE_PROPERTY(calderbank_db, c, t)
/* Accessing the liquid domain */
mix = THREAD_SUPER_THREAD(t); /* Pointing to mixture thread */
liq = THREAD_SUB_THREAD(mix, 0); /* Pointing to liquid phase */
/* Define the variables */
real db; /* Bubble diamter placeholder */
/* Get local conditions from the dispersed (gas) phase */
real eps = C_D(c, liq); /* Obtain turbulence dissipation from liquid phase */
real eG = C_VOF(c, t); /* Volume fraction of the gas phase */
/* Liquid properties */
double density_liq = 998.2; /* Density of liquid phase (kg/m³) */
/* Ensure epsilon is positive to avoid division errors */
if (eps <= 0.0)
eps = 0.0000000001; /* Small value to prevent singularity */
if (eG > 0.3)
db = 0.0000001; /* almost zero db */
/* Calderbank's model (1958) for pure liquid */
/* db = C1 + C2 * ((surf_tension / rhoL)^0.6 / eps^0.4) * eG^0.5 */
db = 0.0009 + 4.15 * pow(0.072 / density_liq, 0.6) * 1 / (pow(eps, 0.4)) * pow(eG, 0.5);
return db;
DigiHctrGT is offline   Reply With Quote
bubble, define_property, diameter, udf
UDF bubble diameter CeesH Fluent UDF and Scheme Programming 9 May 20, 2023 02:54
Define chemkin mechanism and UDF for combustion problem in Fluent. Deepak Chauhan Main CFD Forum 0 August 13, 2020 07:02
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 21:13
UDF carbon conversion papteo Fluent UDF and Scheme Programming 1 August 18, 2011 07:32
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
