integrate mass flow rate over time in new variable
Old   March 25, 2025, 15:13
Default integrate mass flow rate over time in new variable
Svetlana Tkachenko
Svetlana is on a distinguished road
Hi, please see https://www.cfd-online.com/Forums/fl...ost881328.html I would like to move it to this forum section, but don't see a button to do it.
Trying to define a custom variable which varies with space. The goal is to track how much fluid entered at inlet (as distribution, i.e. different in each point, not only 1 number)
Tried to add user defined scalar with confusing results
Tried uds + udf with less confusing results, but still not looking reasonable
Details at the link above
Thanks in advance for your help.
Svetlana is offline   Reply With Quote
Old   March 25, 2025, 15:20
Svetlana Tkachenko
kind of solved it by apu=0, at least it is linear decrease now - will now need to define non-constant as next step - i will keep you updated. (didn't understand what apu 'central coefficient' term is for)
Postprocess: sampleDict works but creates no output folder shock77 OpenFOAM Post-Processing 14 November 15, 2021 08:27
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 08:38
DPM total mass flow rate yow FLUENT 0 July 17, 2015 12:01
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 13:14
