UDF not extracting data from 3D model accurately in Fluent
Old   May 12, 2025, 10:50
Exclamation UDF not extracting data from 3D model accurately in Fluent
TanmayK
tanmaymkhare is on a distinguished road
Hello all,
I'm trying to write a simple UDF to extract the face area magnitude and outlet flow rate for the outlet face of a straight pipe. It is a transient simulation. The problem I'm facing is that the UDF is giving output of 0.0 for both parameters mentioned above, randomly for certain timesteps. I agree that the outlet flow rate value can be zero at certain time steps but the face area magnitude cannot be zero ever, and that's what is puzzling me as to why it is giving a 0.0 value as output.
The UDF is executed at the end of every time step. I print the values extracted by the UDF in a text file at every time step. Eventually I want to use these values extracted by the UDF for calculations performed by a 3-element Windkessel model at every time step, and therefore it is important that the UDF extracts correct values at every time step.
Pipe diameter = 4cm, length = 30cm
Inlet BC: transient velocity profile
Outlet BC: transient pressure profile
Time step = 0.001 s
I have attached photos of the geometry, the inlet and outlet boundary conditions profiles, the UDF code written in C that I'm using, and a photo of the output file which shows the erroneous output values (highlighted in yellow). I would really appreciate if someone can point what is going wrong with the UDF.
Following is the UDF I'm using:
#include "udf.h"
#include <stdio.h>
DEFINE_EXECUTE_AT_END(print_outlet_flow)
    Domain   *d;
    Thread   *t;
    face_t    f;
    real      area_vec[ND_ND];
    real      face_area;
    real      vol_flow;
    real      total_area     = 0.0;
    real      total_vol_flow = 0.0;
    static int first = 1;
    FILE     *fp;
    int       outlet_zone_id = 6;  /* <<< set this to your outlet face-zone ID */
    /* get the domain and the outlet thread */
    d = Get_Domain(1);
    t = Lookup_Thread(d, outlet_zone_id);
    /* open file once for header, then append thereafter */
    if (first)
        fp = fopen("outlet_flow.txt", "w");
        if (!fp) { Message("Error: could not open outlet_flow.txt for writing\n"); return; }
        fprintf(fp, "Time\tTotalArea\tTotalVolFlow\n");
        first = 0;
    else
        fp = fopen("outlet_flow.txt", "a");
        if (!fp) { Message("Error: could not open outlet_flow.txt for appending\n"); return; }
    /* loop over all faces in the outlet thread */
    begin_f_loop(f, t)
        /* get face‐area vector and magnitude */
        F_AREA(area_vec, f, t);
        face_area = NV_MAG(area_vec);
        /* get volumetric flux through this face */
        vol_flow = F_FLUX(f, t);
        total_area     = total_area + face_area;
        total_vol_flow = total_vol_flow + vol_flow;
    end_f_loop(f, t);
    /* write time, total area, and total volumetric flow rate */
    fprintf(fp, "%e\t%e\t%e\n",
            CURRENT_TIME,
            total_area,
            total_vol_flow);
    fclose(fp);
Looking forward to hearing from you all!
Thank you.
tanmaymkhare is offline   Reply With Quote
fluent udfs, output to file, pipe flow, udf and programming, windkessel
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 9, 2022 23:58
Integration of a Custom C++ Model into FLUENT Syed Haider FLUENT 2 March 6, 2018 23:37
Integrating data from UDF to Fluent say2017 FLUENT 0 October 20, 2017 13:50
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 10:29
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
