Clarification on the writing for the user defined function to be imported into Fluent
Old   October 1, 2025, 21:40
Default Clarification on the writing for the user defined function to be imported into Fluent
Ketan Karkare
kkarkare is on a distinguished road
I've written a UDF to model the absorption kinetics of a metal hydride reactor. Before proceeding with my simulation, I would like to confirm the logical flow of my code, particularly the calculations for equilibrium pressure (\(P_{eq}\)) and the reaction rate.
:Background
The model is based on the modified van't Hoff equation for temperature-dependent equilibrium pressure. The reaction rate is dependent on the local temperature and the pressure ratio (\(P/P_{eq}\)). I am using a User-Defined Scalar (UDS) to track the hydrogen concentration in the hydride.
Request: Could someone please review the following snippet of my C code and confirm if the logic correctly implements these physics?
Specifically, I'd like to verify: The calculation of P_eq and the reaction rate. The correct use of Fluent macros to read temperature and pressure.The handling of the absorption condition (pressure > P_eq).
Here, the temperature will change based on the reaction, which will change the P_eq and eventually the reaction logically ends once the P_eq=Ps. So I don't know how to add a variable like temperature so that in Fluent, I will have the temperature change at each cell, which will be observed by the Simulation with the effects as well. I am not an expert in C code, more like a MATLAB guy. Please guide me through the code formatting and how to put this in Fluent for the simulation.
Thank you
Code Snippet:
kkarkare is offline   Reply With Quote
../externals/cgns/hdf5/H5public.h:63:10: fatal error: mpi.h: No such file or director Mohsin1 SU2 8 November 25, 2023 04:46
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 10, 2022 00:58
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
