[Sponsors] | |||||
Breakage of solid Particles in Fluent DPM using udf |
RV
Rep Power: 3 ![]() |
I am trying to study the Breaking of solid particles after striking the surface of a pipe along with fluid, currently using DPM and for solid particle breakage, I used a UDF in post-processing. I give variable diameter using tabulated in injection consisting of diameters upto 600microns. I also checked with fluent that it is reading table correctly and showing all the particle diameters but after simulation in post processing, the max size i get even at inlet, is 80 microns. Can Anyone suggest how to achieve the correct results what are the ways ?
| Tags |
| dpm, fluent, particle, udf |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can DPM particles undergo solid-liquid phase change in Fluent standard features? | Yoshiki | FLUENT | 0 | October 24, 2025 06:33 |
| The udf for "PSI-C" method in FLUENT DPM? | xsp2020 | FLUENT | 0 | August 27, 2021 23:37 |
| Fluent UDF for moving laser heating of a solid block | Cooper24 | Fluent UDF and Scheme Programming | 7 | July 9, 2021 06:56 |
| Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. | Ari | Fluent UDF and Scheme Programming | 4 | May 31, 2016 09:51 |
| Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
