Can someone help me with an UDF for a rotatory mesh?
Old   August 1, 2013, 23:27
Default Can someone help me with an UDF for a rotatory mesh?
Arthur Loginow
Maralady is on a distinguished road
Hello, I am trying to create a code to this geometry, as you can see at the images it is a simple geometry, it is a pipe with 2 bodies rotating inside, so far I have been reading the UDF manual, and I made a code I would like to make some questions but first here is the code:
#include "udf.h"
DEFINE_CG_MOTION(Rotation,dt,vel,omega,time,dtime)
Thread *t;
face_t f;
/*reset velocities*/
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
/*not too sure what this is for*/
if (!Data_Valid_P())
return;
/*get the thread pointer for which this motion is defines (I assume that this is the cell zone that I made)*/
t = DT_THREAD(dt);
/* motion */
velocity[0] = 0;
velocity[1] = 0;
velocity[2] = 0;
omega[0] = 0;
omega[1] = 0;
/*This will be just a random number, I will try different values anyway*/
omega[2] = 120;
/*not sure how to do the loop and if I should make the loop for faces or cells*/
Question 1: Do I have to create a UDF for each body? Or can I include both bodies at the same UDF?
Question 2: Well as you can see at the code, I am not quite sure of how to make the loop (I have a decent programming knowledge, and because of this forced to learn C, I know how to create a loop, but I do not know what variables to include for the loop, so far I know the pointer will tell the program to use some faces/cells and that leads me to my other question)
Question 3: Should I use faces or cells for the Loop?
Question 4: There is something that I am missing?
I read just the first 2 chapters of the UDF guide, I will finish all the guide soon, but I think that the next chapters will not clear those doubts.
Thanks
Maralady is offline   Reply With Quote
Old   August 3, 2013, 11:17
Arthur Loginow
I would like to know if I should use the cells or the faces, so far I understand that I should use the faces because that will make the adjacent cells to move as well and that is what I am looking for
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Help with UDF to change mesh by external mesh generator zou_mo Fluent UDF and Scheme Programming 1 July 1, 2009 04:57
with UDF to change mesh by external mesh generator zou_mo FLUENT 0 June 30, 2009 07:15
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
