dynamic UDF error: "... fl6315s.exe was not found. ..."
Dear all,
I am so poor to encounter such a poor problem when I was trying to load UDF. 'This application has failed to start because fl6315s.exe was not found. Re-installing the application may fix this problem.' Does anyone ever come across this problem? Sincerely, Shengyi |
Same Problem
I have same problem too, have you found any solution for it?
Since last couple of weeks I use to received the same warning every time I starter fluent. Although after closing the warning window fluent worked normally. I re-installed Ansys and now everything is back to normal.
