March 16, 2009, 06:22 |
time dependent source using DEFINE_SOURCE
Hi!
I'm doing a transient analysis is a 2D channel: ..............____________________________ heat --> |............................................ | flux ---> |____________________________| fluid ---> ----------------axis-------------------- ..............____________________________ heat --> |............................................ | flux ---> |____________________________| I want to have a time dependent heat flux for the side walls (shown above). I'm using the following code but I get the following error: "chip-exec: qmax_source: wrong return type: void udf function expected" I'm hooking the udf under Boundary Conditions --> Wall --> Heat Flux What's wrong? Thank you in advance. Code:
/**************************************/ /* UDF for specifying time dependent heat source */ /**************************************/ #include "udf.h" #define QMAX 156589 DEFINE_SOURCE(qmax_source,c,t,dS,eqn) { real source; real time = CURRENT_TIME; if (time <= 100) /* time 0-100 q = QMAX */ { /* source term */ source = QMAX; /* derivative of source term. */ dS[eqn] = 0.; } if (time > 100 && time < 200) /* time 100-200 q = 0 */ { source = dS[eqn] = 0.; } if (time >= 200 && time < 300) /* time 200-300 q = QMAX */ { source = QMAX; dS[eqn] = 0.; } if (time >= 300 && time <400) /* time 300 -400 q = 0 */ { source = dS[eqn] = 0.; } else if (time >= 400)/* time 400- q = QMAX */ { source = QMAX; dS[eqn] = 0.; } return source; } |
March 16, 2009, 06:55 |
Henrik Ström
This is not my area of expertise, but anyway... What the error message is saying is that you are using the wrong type of macro. It seems you cannot hook a DEFINE_SOURCE-macro to the BC->Wall->Heat Flux panel. I suggest you try writing a DEFINE_HEAT_FLUX-macro instead (see UDF manual chapter 2.3.8)? Hope this helps!
/Henrik |
March 16, 2009, 07:38 |
Dragos
Rep Power: 20 |
Hi T81,
Did you try to use DEFINE_HEAT_FLUX or DEFINE_PROFILE macros? Dragos |
March 16, 2009, 07:42 |
Now I'm trying the DEFINE_PROFILE macro and its seems to work.
Thanks both of you for the replies. |
February 28, 2011, 13:16 |
lyes
Hello T 81 i'm a student I 'm working on simulate a turbulent flow in a rectangular channel were heat blocks are amounted using Fluent i had some problems need a help if u can hlp me write to me lyes43@yahoo.com
February 28, 2011, 17:23 |
Hi lyes43,
I would be glad to help you (if I'm able to...) if you could describe your problem more specifically. You can start a new thread for that, if this is not the appropriate thread. Regards, t81 |
define_source, time dependent |
Time Dependent Temperature Dependent BC Analysis | RP | Main CFD Forum | 1 | March 28, 2008 01:22 |
Linearization of time dependent source variable | CFDtoy | Main CFD Forum | 0 | June 1, 2007 14:05 |
Time dependent Energy source | Nitesh | Main CFD Forum | 0 | July 17, 2006 13:19 |
time dependent energy source | Nitesh | FLUENT | 0 | July 17, 2006 13:14 |
time dependent source | gbj | FLUENT | 1 | April 9, 2005 08:06 |
