problem with UDF for (v2-f) turbulence model in fluent |
May 12, 2009, 09:39 |
Hi.
I found the v2-f UDF (Durbin turbulence model) to link with fleunt software, but it contains several errors when I compile it. I also use interpret option for udf in fleunt but it is not working.what is the problem? please help me. (I found two papers that the writers claimed that they could do this work without any problem.) |
May 15, 2009, 05:49 |
Amol Ramteke
Cheak with header file, and the udf use
May 20, 2009, 16:29 |
You post the udf and corresponding papers here, and we can help you check it out.
June 5, 2009, 16:51 |
thabk you.here is the udf.
June 13, 2009, 09:39 |
any reply? I am waiting for anyone using this turbulence model.also this model released via the original package of FLUENT. could anyone check it?
August 23, 2009, 04:59 |
John Yang
Sorry,but I can't help on the UDF file.
If you use Fluent 6.3.26,you can activate v2f model by typing (allow-v2f-model) in the console window. |
January 17, 2014, 05:50 |
Udf
Hi artemiss1984,
I would like to use this udf but I do not understand in which equation they use the UDS_FLUX and how program recognize the difference between UDS_FLUX cases and diffusivity cases as they have same name? I am trying to solve simple pipe flow but I am getting access violation errors. can you help me in order to solve this problem! thanks in advance! |
Fluent - license problem. | Marcin | FLUENT | 3 | April 13, 2018 16:33 |
Integration of a Custom C++ Model into FLUENT | Syed Haider | FLUENT | 2 | March 6, 2018 23:37 |
Turbulence model problem? | PattiMichelle | Phoenics | 0 | July 11, 2007 19:35 |
Turbulence modeling for fan/compressor blading | Jonas Larsson | FLUENT | 1 | April 13, 2005 14:08 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 04:34 |
