udf define property on a wall surface
Old   September 16, 2009, 16:09
Question udf define property on a wall surface
beibei
bzhu is on a distinguished road
I need to define aborption coefficient as a function of position x on a wall surface (pipe). FLUENT didn't seen to render it even though it could interprete. What could it be wrong? Couldn't fluent render udf on a surface? Thanks!
Here's my code:
#include"udf.h"
DEFINE_PROPERTY(absorption_coefficient, c, t)
real abs_coeff;
real x[ND_ND];
C_CENTROID(x,c,t);
if (x[0] > 0 && x[0] < 0.2)
abs_coeff = 593.9187;
elseif (x[0] > 0 && x[0] < 0.2)
abs_coeff = 197.6521;
abs_coeff = 177.0521;
abs_coeff = 140.5854;
else
Message(
"Abs coefficient for this cell %e = %e", x[0],abs_coeff);
return abs_coeff;
bzhu is offline   Reply With Quote
Old   November 27, 2011, 11:10
Default udf
arash
arashoil is on a distinguished road
hi,
can i modelling asphaltene precipitation that exist in crude oil by uusing ceramic filter monolit by defult formolation in fluent?
i want to modelling separation of asphaltene from crude oil by 19-channel ceramic filter,but i think it is not define in FLUENT that precipitate asphaltene on surface of ceramic channel base on diffrences between pore size.
i must write UDF for this porpuse or not?
most of oil flow must pass through the membrane wall and most of asphaltene must form a gel-layer and precipitation on inner surface od channel.
please help me as soon as possible
thank you so much
arashoil is offline   Reply With Quote
UDF for slip and moving wall lichun Dong FLUENT 3 March 26, 2014 04:37
Wall motion as a UDF, is it possible? linch FLUENT 1 August 31, 2009 09:18
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
UDF to monitor minimum pressure on the wall Arvind Jayaprakash FLUENT 0 September 20, 2007 11:53
How to use UDF to define a moving wall lingo FLUENT 4 April 14, 2004 04:14
