UDF compiler help
Old   March 27, 2010, 07:50
Default UDF compiler help
Hongjin Wang
sosososo1114 is on a distinguished road
dear all;
I encountered a problem when i compile the udf in fluent's tourial champter 21. When I try to build Libary 'libudf' as it says in the tourial, Fluent always messages me that Link: fatal error Link 1104 can not find LIBCMT.lib.
What's wrong? Could u tell me what should I do? I do have this file in my visual studio 2008...
MAny thxs
sosososo1114 is offline   Reply With Quote
Old   March 27, 2010, 08:15
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Do you have set the correct PATH variables?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 27, 2010, 20:48
Hongjin Wang
Thank ur reply. I set the system PATH variable as the path of mspdb80.dll, 'H:\program file\ microsoft visual studio9.0\VC\bin'. I am not sure wheter it is correct. And are there aother PATH variables asking a resetting?
Old   March 27, 2010, 22:59
Hongjin Wang
THx dear all, by asking another experienced fluent user, I have solved my problems.
I ran the FLuent.exe in the visual studion command prompts. And then the conduct.c can be compiled.
Here is another thing I would like to share with u. I dont install my studio on the system disk. That is to say Micro SDks and M VS are in deferent disks. Thus when I load fluent in the command prompts at first time. Fluent messages another bug: Link error 1141, can not open kernel32.lib. The solution can be as essy as copying kernael32.lib into /vc/lib
regarts
Old   March 28, 2010, 04:17
sega's Avatar
Sebastian Gatzka
Ok, great. Than have fun with FLUENT.
Old   March 28, 2010, 22:01
Smile
Hongjin Wang
Thanks Sega!
Old   January 20, 2011, 07:03
xingangzheng
ustbdynamic is on a distinguished road
Dear sosososo1114 ,
I have encountered the same problem you issued. Would you like to tell me how to solve this problem in detail. How to run the FLuent.exe in the visual studion command prompts?
Thank you very much!
regarts
ustbdynamic is offline   Reply With Quote
Old   January 20, 2011, 08:34
DoHander is on a distinguished road
@xingangzheng
1. Add fluent to your Windows path (this means that if you write fluent in the Command Prompt and press Enter it will start Fluent), for adding a program to the Windows path do a search on Google.
2. Open Visual Studio 20xx Command Prompt and from here start Fluent, this way Fluent will know where to search for the C compiler.
Do
DoHander is offline   Reply With Quote
Old   January 21, 2011, 00:11
xingangzheng
Dear DoHander,
Thank you very much for kind help!
I will try it.
Originally Posted by DoHander View Post
@xingangzheng
Do
Old   January 24, 2011, 05:02
Default Udf
Tobino
tobino is on a distinguished road
Hi everybody,
I am studying UDF, but I do not know how to run it. I am already setup Virual stdio 2008. But it is not run.
Please help me !
tobino is offline   Reply With Quote
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
UDF compiler michilin FLUENT 2 January 3, 2007 10:24
Compile UDF with a C++ compiler Luca FLUENT 7 December 26, 2005 23:05
C++ Compiler for UDF Dmitriy Makarov FLUENT 1 December 12, 2000 02:41
