May 30, 2010, 12:38 |
Inlet pressure
ali
Rep Power: 16 |
I simulated over expanded nozzle at 1 bar ambient , steady state with mass flow rate inlet condition. super sonic gauge presure i used 70 bar
now i wanted to change inlet pressure with respect to time . i give in put using #include "udf.h" DEFINE_PROFILE(unsteady_pressure, thread, position) { float t, pressure; face_t f; begin_f_loop(f, thread) { t = RP_Get_Real("flow-time"); pressure = 200000+300*t; F_PROFILE(f, thread, position) = pressure; } end_f_loop(f, thread) } and solved for 10 milli second and saved file.. when i look at result no change in pressure , remains 70 bar I did change the pressure inlet from constant to ydf pressure someone can help Regards Ali |
May 31, 2010, 19:15 |
omid
Rep Power: 16 |
maybe it could be helpful
#include "udf.h" DEFINE_PROFILE(unsteady_pressure, thread, position) { face_t f; begin_f_loop(f, thread) { real t = RP_Get_Real("flow-time"); F_PROFILE(f, thread, position) =200000+300*t; } end_f_loop(f, thread) } Last edited by om1234; May 31, 2010 at 19:39. |
June 2, 2010, 05:34 |
Max
Rep Power: 17 |
If I understand you right, you are using a mass-flow inlet BC. In this case supersonic/initial gauge pressure is only used for initializing the solution and your udf will not have any effect for the rest of the computation.
cherrs |
June 2, 2010, 08:01 |
ali
Rep Power: 16 |
means i should give mass flow inlet using udf?
can you help how? also if i have particles in flow how to give it using udf also? plz help Regards ali |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
Pressure Inlet Boundary Condition | Prasad | FLUENT | 6 | April 9, 2013 21:32 |
How to give pressure inlet in Fluent | Vijayaragavan | FLUENT | 2 | December 13, 2007 03:21 |
about pressure inlet boundary | Sastry(CFD Forum) | FLUENT | 0 | February 19, 2007 02:55 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
