June 5, 2010, 00:49 |
enum
MASOUD
Rep Power: 17 |
Hi;
I need to define two scalars (UDS) and below you can find the UFDs for the aforementioned scalars. I'm just wondering what does the "enum" do??? And shall I change anything? ******************** UDS-01 ******************** #include "udf.h" #include "sg.h" /* Define which user-defined scalars to use. */ enum { E_CHARGE_UDS, C_CHARGE_UDS, N_REQUIRED_UDS }; static real ACT_AREA_A=270000; static real REF_EXCH_CURR_A=2.25; static real MW_H2=0.002; static real MW_CO2=0.044; static real MW_H2O=0.018; static real MW_MIX; static real X_H2; /*static real X_CO2;*/ /*static real X_H2O;*/ static real ALPHA_A=0.5; static real ALPHA_C=1.5; static real NO_ELEC=2; static real FARADAY=96485; static real UNI_GAS_CONS=8.314; static real RXN_RATE_A; static real Z; static real ZZ; static real ZZZ; static real source; DEFINE_SOURCE(ELECT_SOURCE_ANODE,c,t,dS,eqn) { MW_MIX=MW_H2*C_YI(c,t,0)+MW_CO2*C_YI(c,t,2)+MW_H2O *C_YI(c,t,3); X_H2=C_YI(c,t,0)*MW_H2/MW_MIX; /*X_CO2=C_YI(c,t,2)*MW_CO2/MW_MIX;*/ /*X_H2O=C_YI(c,t,3)*MW_H2O/MW_MIX;*/ Z=ACT_AREA_A*REF_EXCH_CURR_A*(pow((X_H2),0.25)); ZZ=exp((ALPHA_A*FARADAY*(C_UDSI(c,t,0)-C_UDSI(c,t,1)))/(UNI_GAS_CONS*C_T(c,t))); ZZZ=exp(-(ALPHA_C*FARADAY*(C_UDSI(c,t,0)-C_UDSI(c,t,1)))/(UNI_GAS_CONS*C_T(c,t))); RXN_RATE_A=Z*(ZZ-ZZZ); source=-RXN_RATE_A; dS[eqn]=0; return source; } ************************** UDS-02 ************************** #include "udf.h" #include "sg.h" /* Define which user-defined scalars to use. */ enum { E_CHARGE_UDS, C_CHARGE_UDS, N_REQUIRED_UDS }; static real ACT_AREA_C=300000; static real REF_EXCH_CURR_C=0.4; static real MW_O2=0.032; static real MW_CO2=0.044; static real MW_MIX; static real X_O2; static real X_CO2; static real ALPHA_A=1.5; static real ALPHA_C=0.5; static real NO_ELEC=2; static real FARADAY=96485; static real UNI_GAS_CONS=8.314; static real RXN_RATE_C; static real Z; static real ZZ; static real ZZZ; static real source; DEFINE_SOURCE(ELECT_SOURCE_CATHODE,c,t,dS,eqn) { MW_MIX=MW_O2*C_YI(c,t,1)+MW_CO2*C_YI(c,t,2); X_O2=C_YI(c,t,1)*MW_O2/MW_MIX; X_CO2=C_YI(c,t,2)*MW_CO2/MW_MIX; Z=ACT_AREA_C*REF_EXCH_CURR_C*pow(X_O2,0.375)*pow(X _CO2,(-1.25)); ZZ=exp((ALPHA_A*FARADAY*(C_UDSI(c,t,0)-C_UDSI(c,t,1)))/(UNI_GAS_CONS*C_T(c,t))); ZZZ=exp(-(ALPHA_C*FARADAY*(C_UDSI(c,t,0)-C_UDSI(c,t,1)))/(UNI_GAS_CONS*C_T(c,t))); RXN_RATE_C=Z*(ZZ-ZZZ); source=RXN_RATE_C; dS[eqn]=0; return source; } |
what's mean enum in udf | zhu | FLUENT | 2 | April 7, 2003 03:20 |
