May 26, 2014, 22:54 |
Scheme command for volume-average value
Jemyung Cha
Rep Power: 16 |
Hi guys.
I am doing some works about monitoring and changing boundary conditions with scheme language. I already know how to get area-weighted-avg temperature like below. These two TUI commands are same. One is scheme and another one is journal command. (define check_temp (surface-area-average (list (surface-name->id thermostat)) "temperature")) ;; Scheme command /report/surface-integrals/area-weighted-avg thermostat () temperature , ;; Journal command But, I do not know how to get volume-average temperature and heat source value in specific cell zone with scheme. Is there a anybody who can help me? Last edited by cicatrix; May 27, 2014 at 00:04. |
May 27, 2014, 04:52 |
#2 | |
Rep Power: 26 |
I looked at the User manual, Fluent Text Command list.
You already found "/report/surface-integrals/area-weighted-avg" But now you don't want a surface integral but a volume integral, so I looked further: Quote:
May 27, 2014, 10:09 |
Jemyung Cha
Rep Power: 16 |
Thanks for your helpful explanation.
But I need to know scheme commands to make some codes which can control temperature and source term. |
May 27, 2014, 11:11 |
#4 | |
Rep Power: 26 |
You can turn every journal command into a scheme command by using "(ti-menu-load-string ...)"
So in this case: Quote:
May 27, 2014, 19:37 |
Jemyung Cha
Rep Power: 16 |
I know (ti-menu-load-string ...) can do measure volumename's temperature.
But I need to store variables in memory using the scheme commands. (ti-menu-load-string ...) can just returen #f or #t. |
May 28, 2014, 02:09 |
Rep Power: 26 |
OK, you didn't mention yet that you wanted to use the value, and not just print it.
I now understand your problem, but don't know the solution. I am interested to know the answer, though... |
November 12, 2014, 20:48 |
#7 | |
Younis Najim
Rep Power: 13 |
(ti-menu-load-string (format #f "report volume-int va thermostat () temperature yes yourfilename yes")) ------------------------------------------------------------------ Hopefully not too late |
November 12, 2014, 20:52 |
François Grégoire
Rep Power: 17 |
probably volume-average instead of volume-int
November 15, 2014, 21:35 |
#9 |
Younis Najim
Rep Power: 13 |
November 20, 2014, 07:53 |
#10 |
Jemyung Cha
Rep Power: 16 |
I solved with follwing scheme commands.
(%fill-node-values 'temperature) (define Temp_A (%volume-integrals 'volume-average '(Cell Zone ID) "temperature")) ;; Temp_A is a variable name what you want to make ;; You can get Cell Zone ID in cell zone conditions in flunet window. |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
how to understand high resolution scheme and high order scheme | iilw1314 | Main CFD Forum | 7 | April 12, 2022 12:29 |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
How to obtain turbulent kinetic energy data from LES model of Ansys CFX? | rsin | CFX | 19 | December 29, 2018 04:43 |
2nd order upwind scheme (Fluent and CFX) | Far | FLUENT | 0 | May 22, 2011 01:50 |
