August 24, 2010, 14:54 |
error in compiling udf
sugumaran
hello everyone...
i wrote my udf for real gas model... while compiling i got error message like this,, 1 file(s) copied. (system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2d\makefile") 1 file(s) copied. (chdir "libudf")() (chdir "ntx86\2d")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file. Done. "e:/sugu/vt/2d cases/gambit files/mesh files" Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified. Error Object: () this udf file is just example given in fluent manual only... still i m getting probs.... please help me... |
August 25, 2010, 06:09 |
Dragos
Rep Power: 20 |
This question is very frequently asked.
Most likely the problem is that you don't have a compiler installed on your machine or if you do, then Ansys is not configured to work with it. Last edited by dmoroian; August 26, 2010 at 04:09. |
August 25, 2010, 14:19 |
sugumaran
hello dmoroian....
Thanks for reply.. bt i had installed Visual c++ 2005 Express version.. thing is its working in Linux system.... thanks.. |
August 26, 2010, 04:02 |
Dragos
Rep Power: 20 |
Search the forum for similar posts or check this wiki article:
http://www.cfd-online.com/Wiki/Fluen...at_is_wrong.3F |
August 26, 2010, 09:35 |
sugumaran
Thanks dmoroian sir....
i ll check out those things..... |
August 26, 2010, 15:25 |
error after load the udf
sugumaran
hello everyone....
now the udf is compiling and loading without error... but while running the simulation at the bigining itself giving error, says Absolute pressure Limited to 1.0000e+00 Error:> (Greater-than) : invalid argument [2] : wrong type [not a number] Error object : nan what i means.. where should i correct.. thanks sugu |
About UDF compiling issues: 'nmake' | Haoyin Shan | Fluent UDF and Scheme Programming | 15 | November 4, 2019 18:05 |
Compiling UDF on a cluster | Adya | FLUENT | 1 | December 14, 2009 11:30 |
UDF compiling problem in Flient 6.3 | jeevan kumar | FLUENT | 2 | February 25, 2009 00:43 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 07:14 |
On Compiling a UDF | David Chabot | FLUENT | 5 | May 20, 2005 09:13 |
