How to access all nodes and pressures.
Hi everyone;
I need to calculate the deformation of geometry. The pressure will effect on the geometry, deform=(xx[j+1]-xx[j])*presur[j]*log(fabs((xx[ii+1]+xx[ii])/2.-xx[j])*fabs((xx[ii-1]+xx[ii])/2.-xx[j])) ,so I need to access all nodes and keep the pressure and x-coordinates in P[] , x[] for calculatiog the deformation equation. This is my UDF ( it is not working, when i run, it will show the message "fetal error" #include "udf.h" DEFINE_GEOM(deform_ball, domain, dt, position) { Thread *t; face_t f; /*real xx[1000]; real yy[1000]; real presur[1000]; */ real x[ND_ND]; real NV_VEC (A); real ho=0.01, hc, def,e=345230000000.0, wref, deform,n; real r=10.0,b=0.00039,ap=800000000.0, vb=1.0, vp=0.3; int max,i,j,ii,size; node *n; n=F_NODE(face, thread, n); real *px=NULL; real *xx=NULL; real *yy=NULL; px=(real*)malloc(n*sizeof(real)); xx=(real *)malloc(n*sizeof(real)); yy=(real *)malloc(n*sizeof(real)); i=0.; begin_f_loop (f, t) { F_CENTROID(x,f,t); xx[i]=x[0]; yy[i]=x[1]; presur[i]=F_P(f, t); max=i; i=i+1; } end_f_loop (f, t); i=0.; j=0.; ii=0.; for(j=0;j<max;j++) { if (position[0]==xx[j]) goto start; } start: for(i=0;i< max;i++) { ii=i; if (i==max) { ii=max-1; } if (i==0.) { ii=1; } if (j==max) { j=max-1; } deform=(xx[j+1]-xx[j])*presur[j]*log(fabs((xx[ii+1]+xx[ii])/2.-xx[j])*fabs((xx[ii-1]+xx[ii])/2.-xx[j])); } hc=-2*(vb-vp)*deform/(e*3.14); position[1]=position[1]*0.9+0.1*(ho+sqrt(fabs(yy[j]*yy[j]-r))+(hc)); position[1]=position[1]; free(xx); free(yy); free(presur); Message ("x = %f, y= %f, deform=%f",position[0],position[1]),deform; return position[1]; } Thanks you |
