(ask) how to create UDF for inlet velocity profile |
May 29, 2013, 05:04 |
salam
#41 |
tehran
Rep Power: 12 |
hi amir .can i ask u about sth about b.c with udf
August 14, 2013, 12:05 |
Defining TOP HAT VELOCITY profile
#42 |
Yunusrulz
Rep Power: 13 |
I want to define a top hat velocity profile at my inlet. I dont know the code to define top hat velocity profile. does any body know it. Please answer.
January 14, 2014, 04:58 |
Velocity inlet UDF in fluent
#43 |
Akshay Khadse
Rep Power: 12 |
hi guys,
I want to use a user defined function for velocity inlet for following conditions: v_x = (2/3)*z for z = 0 to 30 v_x = 20 for z = 30 to 70 v_x = (200/3)-(2/3)*z for z = 70 to 100 It is for 3D compressor cascade inlet. I do not know how to write such functions. Can anyone help me? |
July 9, 2014, 13:01 |
#44 |
Srivathsan N
Rep Power: 13 |
I have a 2D axisymmetric geometry where I want to impose a non uniform velocity field in the fluid region (not a boundary, but the internal field). I have the coordinates and the axial and radial velocity components from a previous simulation. How do I go about importing this into the current case. Also is there a better way to store the velocity value other than File -> Export? Thanks in advance
Regards, Srivaths |
January 12, 2016, 10:03 |
Periodic BC DDPM, UDF
#45 |
Rupesh Verma
Rep Power: 12 |
Dear Friend,
I am using, DDPM simulation using ANSYS 14.5, for a simple system. I used inlet as periodic and outlet as shadow in ANSYS for making it periodic but after making periodic I have no control on the inlet (I am unable to specify mass flow rate inlet), it is showing option to specify pressure gradient. Thanks for helping in advance!!! |
April 25, 2016, 18:41 |
UDF for inlet y velocity 2D
#46 |
Keyu Dhingani
Rep Power: 10 |
I have seen and used UDFs for the inlet x velocity, but what do I do to make a UDF for inlet y velocity. Here is the UDF that I used for inlet x velocity. [ #include "udf.h" #define umean 10.0 #define R 0.0005 DEFINE_PROFILE(inlet-x-velocity,t,i) { real x[ND_ND]; real y; face_t f; begin_f_loop(f,t) { F_CENTROID(x,f,t); y = x[1]; F_PROFILE(f,t,i) = (3./2.)*umean*(1-pow((y-R)/R,2)); } end_f_loop(f,t) } ] I tried replacing x with y and vice versa to hopefully get the y-direction velocity, but unsuccessful. Any suggestions here will be useful. Thanks, Keyu |
April 26, 2016, 04:58 |
#47 | |
Bruno Machado
Rep Power: 12 |
y = x[1]; If you want a velocity profile normal to the Y direction, you need to use the variation of the position in the X direction if 2D and X and/or Z direction if 3D. |
April 27, 2016, 11:09 |
#48 |
Rupesh Verma
Rep Power: 12 |
Dear
u r right.. |
October 24, 2016, 04:51 |
UDF for inlet temperature
#49 |
mm
Rep Power: 8 |
Dear all
I have following UDF for inlet temperature, untill 1300s it takes correct values according to equation, but after 1300s values are higher and not accorrding to equation, like at 1301s it should have value of 405C but in simulation inlet temperature is 621C. I could not find the error in my UDF after lot of try. please check this and guide me #include"udf.h" DEFINE_PROFILE(inlet_temperature,thread,position ) { face_t f; begin_f_loop(f,thread) { real t = RP_Get_Real("flow-time"); if (t <=1300.0 ) { F_PROFILE(f,thread,position) = 379.13 + 0.0005*t; } else if (1300.0 < t && t <= 1500.0 ) { F_PROFILE(f,thread,position)= -1.04289036878969*pow(10,-10)*pow(t,6.0)+ 8.86126436853789*pow(10,-7)*pow(t,5.0)-3.13621260398811*pow(10,-3)*pow(t,4.0)+5.91804640375908*pow(t,3.0)-6.27969461279651*pow(10,3)*pow(t,2.0)+ 3.55273415252714*pow(10,6)*t - 8.37223405676245*pow(10,8); } else { F_PROFILE(f,thread,position) = -9.51538261322402*pow(10,-23)*pow(t,6) + 8.26192751387975*pow(10,-18)*pow(t,5)-2.85237398505875*pow(10,-13)*pow(t,4)+4.97518353700886*pow(10,-9)*pow(t,3)-4.58733775886876*pow(10,-5)*pow(t,2)+ 2.10251137071757*pow(10,-1)*t +3.57252192344954*pow(10,2); } } end_f_loop(f,thread) } |
October 24, 2016, 10:36 |
#50 |
Rep Power: 26 |
else if (1300.0 < t && t <= 1500.0 ) Code:
else if ((1300.0 < t) && (t <= 1500.0 )) |
January 25, 2017, 02:16 |
Sinus velocity
#51 |
milad
Rep Power: 9 |
Hello
I have a question How write( V=Asinwt) in fluent(udf) Please help me Thank you |
January 25, 2017, 02:47 |
#52 |
Rep Power: 26 |
If you use this UDF:
Message("V=Asinwt"); This is almost surely not what you want, but I can not guess what you really want. You should explain better what you want the UDF to do. Edit: let me be a little bit more helpful, after drinking coffee. If A, w and t are defined variables, and you want to put the result in V, the way to put that in a UDF is: Code:
V = A*sin(w*t); |
January 25, 2017, 22:39 |
Sinus velocity
#53 |
milad
Rep Power: 9 |
Thank you for the answers you have given me. I want to examine the impact of heat transfer in an oscillating jet, for sinusoidal input speed jet was
u = Asinwt The A (Initial velocity), w (period), t (time) But I do not know how to code the program is written udf |
January 26, 2017, 02:56 |
#54 |
Rep Power: 26 |
Look for a UDF that does something similar, and change it.
There are UDFs mentioned in the messages above that do something similar... Read them! |
January 28, 2017, 12:11 |
how to use data from .csv file as inlet boundry condition
#55 |
hemant mittal
Rep Power: 10 |
hello every one
i have data file generated from matlab program which contains fluctuating velocity for atmospheric boundary layer so please guide me how can i use this file as inlet boundary condition thanks and regards |
January 30, 2017, 04:08 |
radial_velocity
#56 | |
SAIF MASOOD
fluentp1-1-02000.jpg t.jpg |
February 11, 2017, 09:54 |
Error message : output pipe has been closed
#57 |
Thomas henderson
Rep Power: 9 |
Hi there,
I have tried to implement this UDF in ansys fluent however it is resulting in an error stating : " output pipe has been closed " Any ideas why this might be? |
February 13, 2017, 04:29 |
#58 |
Rep Power: 26 |
Which one is "this UDF"?
February 13, 2017, 04:50 |
Udf
#59 |
Thomas henderson
Rep Power: 9 |
February 14, 2017, 11:45 |
Syntax error
#60 |
Thomas henderson
Rep Power: 9 |
There is a syntax error in the line :
DEFINE_PROFILE(unsteady_velocity, thread, position) However this is similar to other examples I have seen. Any ideas why this may be? |
UDF problems - velocity profile | Oli | Fluent UDF and Scheme Programming | 6 | October 24, 2016 10:38 |
How to create non-uniform velocity profile in FLUENT? | pankaj | FLUENT | 7 | October 24, 2016 04:52 |
udf for velocity profile in a geometry having two inlets | shubham208011 | Fluent UDF and Scheme Programming | 0 | April 6, 2009 15:13 |
UDF velocity and temperature | Raj | FLUENT | 3 | February 1, 2009 18:29 |
UDF velocity profile at nodes | Emad | FLUENT | 2 | January 29, 2009 06:35 |
