Error message udf file
Old   July 9, 2011, 03:46
Default Error message udf file
A BIBI
Keskidi is on a distinguished road
i want to introduce a velocity profile at the inlet of a 3D tube.
My udf file is:
#include "udf.h"
DEFINE_PROFILE(inlet_z_velocity,thread,index)
real z[ND_ND];
real x;
real y;
face_t f;
begin_f_loop(f,thread)
F_CENTROID(z,f,thread);
x = x[0];
y = x[1];
F_PROFILE(f,thread,index) = 0.217*pow(pow((pow(y,2)+pow(x,2)),0.5)/3.9,1/7);
end_f_loop(f,thread)
When i put it in fluent i've got the message
line11: subscripted expression is not an array or pointer : double
Thks for your help
Keskidi is offline   Reply With Quote
Old   July 9, 2011, 05:06
Josy
Josyula is on a distinguished road
I think z = x[2]; has to be added.
Check and see.
Josyula is offline   Reply With Quote
Old   July 9, 2011, 05:35
A BIBI
Now fluent read the file but it is not what i expect
To be more precise, the face is on the XY plane and the velocity orientated in the z direction.
But if i check the initialization, the profile is flat.
I modified the file like that:#include "udf.h"
real z[ND_ND];
real x;
real y;
face_t f;
x = z[1];
y = z[2];
Old   July 9, 2011, 17:19
Micael
Micael is on a distinguished road
You want to calculate velocity magnitude in z direction?
If I understand what you want, that could be like that:
#include "udf.h"
real coord[ND_ND];  /* face centroid coordinate */
real x;
real y;
face_t f;
    F_CENTROID(coord,f,thread);
    x = coord[0];
    y = coord[1];
    F_PROFILE(f,thread,index) = 0.217*pow(pow((pow(y,2)+pow(x,2)),0.5)/3.9,1./7);
However, the main reason why you got a flat profil is because of "1/7". That is just zero in C language, because operation on 2 integers still gives an integer (integer value of 1/7 is zero). I change it for 1./7 in the code above.
Micael is offline   Reply With Quote
Old   July 9, 2011, 17:48
A BIBI
Yes exactly.
It's working well with 1./7
Thanks a lot
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
