NEED HELP TO create UDF to define a boundary condition automatically |
May 21, 2012, 09:53 |
bon
Rep Power: 13 |
i must create a UDF to define a velocity inlet at the face of my box which is normal to "y axis" and which is the closest and the furthest will be a pressure outlet. and the other faces will be walls.
need a udf because i have many geometries and because the box has been separate in random faces. |
May 21, 2012, 10:11 |
James Willie
Rep Power: 17 |
How are you setting up your case? Not sure if a udf macro exist for doing what you want. But you could use a journal file to help you automatically setup your entire Fluent case including defining your bcs. Jimmy
May 22, 2012, 03:20 |
bon
Rep Power: 13 |
May 22, 2012, 04:20 |
bon
Rep Power: 13 |
If someone has an idee ???
UDF for inhomogenous Neumann boundary condition | akhilesh | Fluent UDF and Scheme Programming | 3 | December 24, 2012 11:14 |
Need help to define Boundary condition | Chirag2302 | FLUENT | 6 | May 7, 2012 06:51 |
[stressAnalysis] how to define a new boundary condition | xck1986 | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 0 | February 23, 2011 04:56 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 02:53 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
