October 3, 2011, 11:24 |
Compiling UDF in Ansys Fluent12
Vishu
I have problem in compiling UDF in ANSYS FLUENT.
I have installed Visual studio in C:\Program Files\Microsoft Visual Studio 9.0 My ansys fluent is intalled inside C:\Program Files. The error it is showing while loading is : open_udf_library: The file is not specified Please anyone help me how to get out of this problem.I am using 32-bit system with Windows XP. the problem might be setting of environment variables.If so kindly let me know how to set them.What path I need to give. |
October 5, 2011, 02:36 |
Jack cosby
Rep Power: 14 |
Do you start fluent from the visual studio command prompt?type in fluent.exe 2ddp(put in 3d or 3ddp .... depending on your case).
to set the env. variables start>fluent>set enviromental variables. this adds fluent to system path, then http://www.cfd-online.com/Forums/blo...fluent-vc.html remember to run fluent from v.s command prompt |
October 5, 2011, 10:09 |
#3 | |
I want to clear these 2 different methods for linking (for both, you need to add FLUENT to path): 1) If you want to launch FLUENT from VC++ command prompt, you won't need to set other parameters which I told in my blog; this method is not permanent and consequently, you need to launch FLUENT by VC++ when ever you need UDF compilation. 2) If you've added VC++ variables to your path, you don't need to launch FLUENT from command prompt, when you start FLUENT normally, you can compile your UDF. Bests,
Amir |
Display Modes | |
Problem with Compiling UDFs in Ansys Fluent 13 (lnx64) | Ali.beh | Fluent UDF and Scheme Programming | 3 | August 27, 2018 05:22 |
my problem wuth UDF compiling | m.beh | FLUENT | 3 | November 22, 2011 01:47 |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 06:11 |
compiling linked udf (C/fortran mixed) | bawfuls | Fluent UDF and Scheme Programming | 0 | July 13, 2010 17:53 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 08:14 |
