Fluent UDF Discontinuous Motion
Old   July 5, 2011, 14:26
Default Fluent UDF Discontinuous Motion
Sebastian
lequi7 is on a distinguished road
Hello you all
Iīm programming Fluent for a flapping-wing simulation. After problems with the UDF compilation, VS-Fluent interaction, UDF programming and motion previewing (all solved thanks to this forum) I finally got it working (its 1DOF for now).
When I preview the prescribed motion, something wierd happens: While the angular velocity is OK (sine motion), the angle is discontinuous. What I mean is that, when the angular velocity changes sign, the angle leaps to another position, where the velocity continues as it should. That is, when changing direction, the wing jumps right into another position, and then is does change direction and continues normally, until it has to change itīs direction again, just to jump again.
Here is the UDF:
#include "udf.h"
#include "dynamesh_tools.h"
DEFINE_CG_MOTION(unGDLsin20,dt,vel,omega,time,dtim e)
real w, a, pi; /* w es frecuencia Hz, a, es amplitud grados*/
pi=3.141592654;
a = 20*pi/180; /* 20 degree flapping amplitude */
w = 2*pi*2; /* 2 Hz frequency */
/* speed initialisation */
NV_S (vel, =, 0.0);
NV_S (omega, =, 0.0);
/* error message */
if (!Data_Valid_P ())
Message("Not good at all!\n");
return;
omega[0] = 0;
omega[1] = a*w*sin(w*time);
omega[2] = 0;
I donīt know if the problem is in the UDF programming, or if itīs a compilation problem, or the way fluent calculates position with the angular velocity provided, or what at all. Any advice is welcome (I really need to finish my thesis)
lequi7 is offline   Reply With Quote
Old   November 1, 2011, 23:20
colopolo is on a distinguished road
Originally Posted by lequi7 View Post
Hello you all
Here is the UDF:
#include "udf.h"
pi=3.141592654;
NV_S (vel, =, 0.0);
/* error message */
return;
omega[0] = 0;
omega[2] = 0;
I have same problem. Please let me know if you solve this problem
Best Regards
colopolo is offline   Reply With Quote
Old   November 3, 2011, 23:18
Sebastian
Best Regards
Colopolo
I messed with it a lot and couldnīt solve it...
Then I switched to another, linux based, computer and it worked like a charm. Compiling was so easy.
I believe my original UDF got messed up along the long way in the Windows *thorny* compiling process.
Hope that helps
cg_motion, discontinuity, dynamic mesh, flapping motion, udf
UDF problem: incorrect grid motion Fil FLUENT 5 December 19, 2020 09:16
UDF to record FLUENT Solver variables... mariachi Fluent UDF and Scheme Programming 11 September 24, 2019 00:07
the udf has been hooked to the fluent successfully,but it does not work! hugeforest Fluent UDF and Scheme Programming 1 July 8, 2011 04:31
UDF to record FLUENT solver variables... mariachi FLUENT 1 February 3, 2010 22:18
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 10:57
