What is the cuase of dynamic mesh no working?
Old   November 18, 2011, 03:04
Default What is the cuase of dynamic mesh no working?
sutthinan
sutthinan is on a distinguished road
Hi Everyone,
I need to make the wall where is deformed by pressure, then I write the UDF code DEFINE_GEOM(deform, domain, dt, position) to define the boundary moving of wall. Everything look fine, but the meshes in side close to boundary were not moving properly, only the boundary is moved. So I quite doubt with this.
I used dynamic mesh-- layer (height base) and mesh element type is Quad
Many thanks,
Sutthinan
sutthinan is offline   Reply With Quote
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
Regarding Negative volume detected in Dynamic mesh Vinay Morabad FLUENT 10 December 16, 2015 00:31
[mesh manipulation] Dynamic Mesh Diffusivity Problem dancfd OpenFOAM Meshing & Mesh Conversion 0 August 29, 2010 11:50
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 15:40
dynamic mesh not working studentwhoneedshelp FLUENT 4 July 24, 2008 03:31
