udf problem
Old   December 22, 2011, 05:55
Default udf problem
rose
rubis is on a distinguished road
hi all;
Please I have a problem in the numerical simulations made ​​by Fluent 6.3 and Ansys Fluent 12.0.16 even when I use the UDF.
it is interpretable but when I put the UDF in the interaction window or in the properties of materials such as for example the viscosity between the two phase fluent displays this message:
Error: FLUENT Received fatal signal (ACCESS_VIOLATION) 1. Note exact events Leading to error. 2. Save case / data Under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
knowing that I work with the VOF model.
I would be very grateful if you help me solve my problem of simulation.
cordially
rubis is offline   Reply With Quote
Old   December 29, 2011, 18:40
Real Name :)
ComputerGuy is on a distinguished road
Rubis,
Usually this happens when you're:
a) trying to access something that fluent isn't calculating (i.e. temperature in a simulation without the energy equation enabled)
b) performing a calculation which "blows up" (divide by zero, NaN errors, etc)
If you post your code, perhaps we can figure it out.
ComputerGuy
ComputerGuy is offline   Reply With Quote
Old   December 30, 2011, 08:08
rose
Thank you for help .
i will do it
best reagards
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
