UDF for heat and mass transfer, transient simulation |
November 11, 2018, 23:46 |
Akash Siddique
Rep Power: 8 |
Hi Everyone !!!
I'm stuck with the UDF for heat and mass transfer between air and desiccant material. In this problem, air passes between the desiccant block, heat & mass transfer happen due to the humidity of air adsorbed by desiccant material on its surface I'm facing difficulty in writing UDF for this problem Equations are given as: dfsfd.PNG Equation 1: Variable Air Temperature(Ta) = 1162 – (100/z), (z = distance along axis=0.01-0.4m) Equation 2: Variable Adsorbent Temperature = .06+ (.05/t^.19), (t=time duration =0-3600) Equation 3: Variable Air Humidity Ratio = -22(41*t^.1)-.625(4/z), (z= distance along axis, t=time) I need your help badly, and I hope you will cooperate afzalkhangm001@gmail.com Here is my email address |
November 13, 2018, 00:08 |
Alexander
Rep Power: 34 |
imagine, you have codes for those tree equations
Equation 1: Variable Air Temperature(Ta) = 1162 – (100/z), (z = distance along axis=0.01-0.4m) Equation 2: Variable Adsorbent Temperature = .06+ (.05/t^.19), (t=time duration =0-3600) Equation 3: Variable Air Humidity Ratio = -22(41*t^.1)-.625(4/z), (z= distance along axis, t=time) best regards |
November 13, 2018, 05:43 |
Akash Siddique
Rep Power: 8 |
Well, I will interpret the UDF in fluent and complete my simulation. I hope this will get good results.
I will be thankful to you if you help me in any way. |
November 13, 2018, 20:47 |
Alexander
Rep Power: 34 |
I mean, which model you a going to use for this simulation?
So you have: - Variable Air Temperature(Ta), function of coordinate - Variable Adsorbent Temperature, function of time - Variable Air Humidity Ratio, function of both time and coordinate Fluent has only one temperature, which is calculated using energy equation. So I can imagine you will initialize temperature field according to Variable Air Temperature(Ta). But what you are going to do with Variable Adsorbent Temperature and Variable Air Humidity Ratio How they are connected to energy/flow equations? best regards |
November 27, 2018, 00:28 |
Akash Siddique
Rep Power: 8 |
Thanks for your kind reply
I must say this is a good question. I'm at the beginning level in Ansys. So, I will try to explain it according to my abilities. Kindly correct me if you find my reasoning inappropriate. I'm learning Ansys by watching youtube videos on similar topics. So, as per my understanding, I need to use " Species model" for air humidity ratio. I think these Two models (Energy, Species) are enough to complete my simulation. Am I on right Track ?? Please enlighten me And I'm extremely sorry for late reply. I hope you will cooperate |
December 5, 2018, 08:12 |
Akash Siddique
Rep Power: 8 |
please somebody help me with UDF
December 6, 2018, 22:57 |
Alexander
Rep Power: 34 |
As I understand, your problem is some kind of condensation/evaporation simulation.
SO I suggest you to start with regular condensation/evaporation simulation, later you may move to implementation of UDF inside, which is not a big deal, actually best regards |
December 7, 2018, 06:32 |
Akash Siddique
Rep Power: 8 |
Thanks for your reply
Actually, I have already completed my work but only missing piece in completing the simulation is UDF. I'm also in the process of learning how to write code but it is taking too much time and I want to complete my simulation soon. So any help will be appreciated Best Regards |
heat and mass transfer, transient simulations, udf |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
UDF for mass and heat source with heat transfer | rajendra1 | Fluent UDF and Scheme Programming | 35 | October 13, 2017 04:04 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
Mass transfer UDF expecting void return | Quinos | Fluent UDF and Scheme Programming | 0 | January 8, 2014 18:36 |
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat | kokoory | FLUENT | 0 | August 17, 2011 02:07 |
