Node Connectivity in Fluent
Old   February 27, 2012, 20:37
Default Node Connectivity in Fluent
Sony
SonyCFD is on a distinguished road
in fluent we can access the node information (position) through node loops in UDF.
Is there any way I can know if one node is connected to another given node?
Thanks and Regards.
Sony
SonyCFD is offline   Reply With Quote
Old   March 7, 2012, 17:25
Real Name :)
ComputerGuy is on a distinguished road
I suppose what you could do is pass a function the pointer of the two nodes in question. Then, the function could loop over every thread, every cell, and every face of the cell to find that node. Once found for node #1, it would be as simple as carrying out the rest of the face loop to determine if they (node #1 and node #2) are co-planar on a face.
Or, are you asking about a direct connection to a specific node? If yes, you could check loop over all faces which contain node #1. Then, loop over all faces which contain node #2 (using method in first paragraph). If there is a non null intersection of those two sets, nodes #1 and #2 are connected.
Certainly there has to be some connectivity tree, given that Fluent is using an unstructured mesh, but I don't recall any Node-->Node connectivity macros.
Wish I could be of more help...But that's a brute force technique. Any other takers?
ComputerGuy
ComputerGuy is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Fluent Parallel Processing Mrxlazuardin FLUENT 2 April 28, 2010 07:36
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 10:55
solving ocean wave with Fluent or CFX? gholamghar Main CFD Forum 1 March 21, 2009 12:49
