Erros hooking UDF for recirculation flow
Like Tree2Likes
  • 1 Post By AlexanderZ
Old   April 17, 2021, 14:33
Post Erros hooking UDF for recirculation flow
Gregori
greg93 is on a distinguished road
Hi everyone,
I'm writing a UDF to simulate the recirculation flow effect of species in a tubular reactor. This UDF also computes the dilution effect in the tank before the reactor. This UDF is compiled with no errors, however, when I try to hook this UDF in the species mass fraction boundary box I got the message below. I've tried to correct it in many ways by reading the Ansys Customization Manual and forums but with no success. Could anybody help me to find out what is the problem with my code? (attached)
I would really appreciate any tips or help, this is an important step in my thesis.
Node 0: Process 6096: Received signal SIGSEGV.
Node 6: Process 14268: Received signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
The fl process could not be started.
#include "udf.h"
#define ST 2.98
#define zone_ID1 8
#define zone_ID2 7
  face_t f;
  real Ain[ND_ND];
  real Aout[ND_ND];
  real area_in = 0;
  real area_out = 0;
  real initial_mfracBACT = 2.17e-07;
  real sum_mfracBACT_in = 0.;
  real sum_mfracBACT_out = 0;
  real mfracBACT_in;
  real mfracBACT_out;
DEFINE_PROFILE(inlet_mfracBACT,t,i)
  Domain *domain = Get_Domain(1);
  Thread *outletthread = Lookup_Thread(domain,zone_ID2);
  Thread *inletthread = Lookup_Thread(domain,zone_ID1);
if(N_TIME < 1)
  F_PROFILE(f,t,i)= initial_mfracBACT;
else
begin_f_loop(f,outletthread)
  F_AREA(Aout,f,outletthread);
  area_out += NV_MAG(Aout);
  sum_mfracBACT_out += F_YI(f,outletthread,4)*NV_MAG(Aout);/*In the species list BACT is in the 4th position*/
end_f_loop(f,outletthread)
mfracBACT_out = sum_mfracBACT_out/area_out;
begin_f_loop(f,inletthread)
  F_AREA(Ain,f,inletthread);
  area_in += NV_MAG(Ain);
  sum_mfracBACT_in += F_YI(f,inletthread,4)*NV_MAG(Ain);
end_f_loop(f,inletthread)
mfracBACT_in = sum_mfracBACT_in/area_in;
begin_f_loop(f,inletthread) /*recirculation effect with dilution effect >> Inletmassfraction-specie1 at every time step= (Outletmassfraction-specie1* time step (s)+ ST*Inletmassfraction-specie1)/(time step (s) *ST)*/
   F_PROFILE(f,t,i) = (F_YI(f, outletthread, 4)*CURRENT_TIMESTEP+ST*F_YI(f, inletthread, 4))/(CURRENT_TIMESTEP+ST);
File Type: c UDF_recirculation_effect_BACT_alternativa2.c (1.6 KB, 4 views)
greg93 is offline   Reply With Quote
Old   April 18, 2021, 23:09
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I think the problem comes from F_YI species mass fraction macro
are you sure that number is 4 ? counting starts from 0
you can initialize case first, then load UDF, not sure that information about mass fraction is available before initialization
since fluent v201 you should make your code suitable for parallel computation, few minor changes:
#include "udf.h"
#define ST 2.98
#define zone_ID1 8
#define zone_ID2 7
  face_t f;
  real Ain[ND_ND];
  real Aout[ND_ND];
  real area_in = 0;
  real area_out = 0;
  real mfracBACT_in;
  real mfracBACT_out;
if(N_TIME < 1)
else
#if RP_NODE
	area_out = PRF_GRSUM1(area_out);
	sum_mfracBACT_out = PRF_GRSUM1(sum_mfracBACT_out);
#endif
#if RP_NODE
	area_in = PRF_GRSUM1(area_in);
	sum_mfracBACT_in = PRF_GRSUM1(sum_mfracBACT_in);
#endif
greg93 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   April 19, 2021, 07:55
Gregori
Dear AlexanderZ,
Thank you very much for taking the time to analyze my code. I'm sure that the index of the Bact species is correct because there are more species involved in the reactions and they are listed starting from 0. I need to recirculate all species, but I'm using this udf to verify the suitability of the code and then I'll copy the code for the other species and make the appropriate changes for each one.
I've tried to load the udf with your suggestions before and after initializing, and also after steady simulation, but with no success. The same errors are displayed. Before initialization, the errors appear by clicking initialize, and after initialization and steady simulation, the errors appear by hooking the udf in the inlet boundary.
Old   April 20, 2021, 00:38
Alexander
to localize the problem try to change F_YI to any constant value, compile and apply. Is problem gone?
do you use multiphase model? in that case may be it is issue with domain definition:
The value of domain_id is always 1 for the mixture domain.
read mode in Ansys Fluent Customization manual -> Domain Pointer
best regards
Old   April 20, 2021, 14:08
Gregori
Dear AlexanderZ,
I've made some changes in the UDF based on a thread that I found in this forum. Now the code looks like this. It is working only when I load the case in serial mode, which is already awesome since I can get some results. However, I'm trying to make it applicable also to parallel mode, using the code lines that you suggested above, but it's not working. I'm reading the customization manual and I hope to get some results in parallel mode.
#include "udf.h"
DEFINE_PROFILE(species_profile, t, i)
/* Declare variables */
face_t f, c;
Thread *outletthread;
Thread *inletthread;
real Ain[ND_ND], Aout[ND_ND], areain=0, areaout=0, sumspeciein=0, sumspecieout=0, ST=2.98, specieout, speciein;
Domain *domain;
domain = Get_Domain(1); /* Returns fluid domain pointer (1 = Mixture) */
outletthread = Lookup_Thread(domain, 7); /* Here put the number of the outlet thread. */
inletthread = Lookup_Thread(domain, 8);/* Here put the number of the inlet thread. */
begin_f_loop(f, outletthread)
/* Loop through faces of your outlet */
F_AREA(Aout, f, outletthread); /* make A the the face vector */
areaout += NV_MAG(Aout);
sumspecieout += F_YI(f, outletthread, 7) * NV_MAG(Aout);
end_f_loop(f, outletthread);
specieout = sumspecieout / areaout; /* specie becomes the average specie */
begin_f_loop(f, inletthread)
F_AREA(Ain, f, inletthread); /* make A the the face vector */
areain += NV_MAG(Ain);
sumspeciein += F_YI(f, inletthread, 7) * NV_MAG(Ain);
end_f_loop(f, inletthread);
speciein = sumspeciein / areain; /* specie becomes the average specie */
begin_f_loop(c, t)
F_PROFILE(c, t, i) = (specieout*CURRENT_TIMESTEP+ST*speciein)/(CURRENT_TIMESTEP+ST);
end_f_loop(c, t);
Old   April 20, 2021, 22:21
Alexander
not sure how it could work in serial either parallel
why did you add loop over cell at the end of the code?
are you trying to define boundary condition (apply to face) or source (apply to zone)? In case of BC you want to have loop over faces.
to have a loop over face you use
begin_f_loop(f, t)
end_f_loop(f, t);
to have a loop over cell
begin_c_loop(c, t)
end_c_loop(c, t);
choose one of them
#include "udf.h"
face_t f, c;
Domain *domain;
#if RP_NODE
	areaout = PRF_GRSUM1(areaout);
	sumspecieout = PRF_GRSUM1(sumspecieout);
#endif
#if RP_NODE
	areain = PRF_GRSUM1(areain);
	sumspeciein = PRF_GRSUM1(sumspeciein);
#endif
begin_c_loop(c, t)
end_c_loop(c, t);
greg93 likes this.
best regards
Old   April 26, 2021, 14:01
Gregori
Dear AlexanderZ,
Indeed the last loop should be over face. Thank you for noting this, I fixed this issue. I'm still working on the UDF trying to make it work in parallel. For serial it is working very well =).
Old   April 26, 2021, 22:33
Alexander
the code I've shared above is ready for parallel
best regards
mass fraction, recirculation, species, udf
UDF bug, for reversing flow direction and magnitude EngGhost Fluent UDF and Scheme Programming 12 April 20, 2020 07:50
How to run multiple cycle pulsetile flow simulation in Ansys fluent using UDF code? Md Al Amin Sheikh Fluent UDF and Scheme Programming 4 January 28, 2020 11:55
volume flow rate for outlet boundry condition and dfine udf for it raminostadi FLUENT 0 December 24, 2016 01:52
UDF for 3D turbulent fully developed flow howhs Fluent UDF and Scheme Programming 0 August 1, 2013 11:47
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
