Help to plot variation of absolute pressure Vs time in transient problem |
April 21, 2012, 07:04 |
Chirag
Rep Power: 14 |
I am analyzing a oscillatory flow in channel. I am using 2D,Pressure based solver, Transient model. I want output at a one point. I had defined a surface monitor at that particular point for Area weighted absolute pressure Vs flow time....I think it is right but my output is as shown in fig. Can anyone help me to correct this??????? Thanks...... |
April 21, 2012, 17:27 |
banty
Rep Power: 14 |
U are getting constant pressure (101325 Pa) but the graph looks strange. should be parallel to time axis ?
April 21, 2012, 17:41 |
#3 | |
Lucky
Rep Power: 65 |
Other than that, it seems (at least your plot) is outputting correctly. If it was a transient simulation I would expect stronger pressure oscillations, but it seems your pressure is fairly constant with small oscillations (these are probably introduced by the averaging scheme). You are also plotting against time-step so it may be hard to judge. |
April 21, 2012, 23:54 |
Thanks
Chirag
Rep Power: 14 |
April 22, 2012, 00:01 |
#5 | |
Chirag
Rep Power: 14 |
I had also monitored with respect to flow time but the output is same. and you are right strong pressure oscillation is expected with amplitude approximately near to 7500 to 8500 Pascals with oscillation frequency of 614 Hz. |
plot pressure vs time |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
