Venturi Modelling Pressure Changes Seem Too Low
Old   April 7, 2012, 17:06
Default Venturi Modelling Pressure Changes Seem Too Low
Patrick Haines
Patrick H is on a distinguished road
I am currently trying to model the flow through a long-form venturi with a beta ratio of about 0.75 and inlet diameter of 0.0525018 m (2.067 in). I have constructed the mesh to replicate an experimental setup, the results of which I will later compare with the results of my CFD model. I am using the standard k-e model with standard wall treatment. Inlet boundary type is mass flow (6 kg/s and 220000 Pa) and outlet is a outflow boundary (flow weight ratio of 1). So far my result look good; clear differential pressure generation and pressure recovery in the divergence cone. However when I plot the pressure distribution my pressure values start at zero and go to about -12 with the units being in Pa. This pressure drop seems far to small and I would prefer if the pressure were displayed in their actual value rather than a negative. Can anyone explain why I am seeing such an unrealistically low pressure drop?
Please let me know if there is any additional information I can supply which would be helpful in determining my problem.
Patrick H is offline   Reply With Quote
Old   April 27, 2012, 03:11
wu
whiz is on a distinguished road
This is because you set the reference as 1 atm. RIght?
whiz is offline   Reply With Quote
pressure plot, pressure scale, venturi
Pressure enigma. Sara Main CFD Forum 22 July 30, 2009 04:46
low base pressure haykozoom FLUENT 0 July 13, 2009 08:34
Low pressure drop with the same model zhoubinwx OpenFOAM Running, Solving & CFD 5 June 16, 2009 05:10
Are NS equations valid at very low pressure ?? Jiri Novak FLUENT 0 August 1, 2007 10:59
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
