August 23, 2004, 16:10 |
Fuel cell modeling
Is there anyone doing PEM fuel cell modeling with Fluent?
I found there is no way to avoid species crossover through the membrane. Fluent takes the whole domain for computation, and does not allow users to deactivate some regions for a certain governing equations, like what FEMLAB does. Can someone with experience give me some hint on how to handle this issue? Your kind help will be appreciated. Steven |
August 26, 2004, 22:47 |
Re: Fuel cell modeling
hi, Steven, you can write a udf to define the diffusivity for each species. the diffusivity of hydrogen/oxygen is sevral orders bigger in gas channel than in membrane(electrolyte), so usually they won't penetrate the membrane through this method. I've seen another approach which employed a big source term to freeze the mole fraction to zero in the region where the species actually does not exist. but i never implenment that successufully. good luck.
-Kevin |
February 18, 2010, 00:43 |
saeed
Rep Power: 16 |
Hello
I modeled a curve pem channel in gambit but when I want to iterate it,I recieve an error and canceled may iterate anyone cana help me? |
February 22, 2012, 18:18 |
Hi , I am used the Fluent for Modeling PEMFC but I found the difficulty ;if you can guide me for modeling correct the all phenomena founded in PEMFC.
ALSO CAN ANY ONE SEND ME THE LINK FOR THE FUEL CELL MODULE TUTORIALS. I AM IN GREAT NEED OF THESE TUTORIALS. THANK YOU |
March 19, 2012, 00:10 |
#5 | |
WU Fei
Rep Power: 14 |
and i will send you the script |
March 19, 2012, 01:10 |
#6 | |
Abdul Halim
Rep Power: 14 |
March 19, 2012, 09:25 |
#7 | |
WU Fei
Rep Power: 14 |
tutorial has already sended to you email,please check it! |
March 20, 2012, 03:12 |
elemad1987@gmail.com
I will be thankful. |
March 27, 2012, 09:33 |
#9 |
Abdul Halim
Rep Power: 14 |
thank you so much,,,
April 29, 2012, 06:51 |
#10 | |
payam gharani
payam.mec1989@yahoo.com thank you so much |
PEM fuel cell modeling | alimech | Main CFD Forum | 4 | April 18, 2020 13:15 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
PEM Fuel Cell Modeling with OpenFOAM | Berker | OpenFOAM | 1 | May 3, 2009 19:16 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
