How to create the rotating reference frame of a MRF problem in DesignModeler wrt to t
Old   May 8, 2012, 01:01
Exclamation How to create the rotating reference frame of a MRF problem in DesignModeler wrt to t
Zev Xavier
Zev Xavier is on a distinguished road
Hi
I am new to Fluent and am wanting to apply a Multiple Reference Frame model to my simple centrifugal pump geometry to analyse the flow behaviour within the pump. I am using an assembly of two components the first being a solid impeller and the second being the geometry of the wetted surface area within the pump housing and volute, please images below. I used SolidWorks for the generation of both components. My currect concern is how to create the multiple zones where two fluid zones are connected via an interface boundary so as to later define the rotating frame in Fluent. I am not sure how to created this in Design Modeler.
Although I am sure this step is rather simple for those already understanding how to create these multiple fluid zone boundary interfaces, It has proved rather challanging for me even after devoting a significant amout of time to understanding this step.
I appreciate any assistance in helping me understand this process.
__
Zev
Impeller:
Fluid Geometry
Zev Xavier is offline   Reply With Quote
Old   May 11, 2012, 03:59
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
There is no need to do it in DM. Treat both separately in DM as well in ANSYS meshing. You should create the interfaces for MRF in Fluent/CFX.
Far is offline   Reply With Quote
centrifugal pump, fluid interface boundary, moving zone, mrf
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
UDF for defining a body force in Singel ROtating Reference Frame teymourj Fluent UDF and Scheme Programming 9 August 18, 2016 15:33
Boundary conditions for rotating reference frame Borna OpenFOAM 1 August 24, 2011 10:25
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 09:03
Rotating Reference Frame Ketan FLUENT 0 May 17, 2007 13:13
