Opening boundary condition
Old   May 10, 2012, 11:10
Default Opening boundary condition
Elias Paez
sicfred is on a distinguished road
Hi all,
My question is quite simple:
Is there an "Opening" BC in Fluent like in CFX? Because, I usually use the "pressure_outlet" to achive this condition (gauge pressure=0), but I'm not really sure if it is a correct solution.
Regards
sicfred is offline   Reply With Quote
Old   May 11, 2012, 02:21
delaneyluke is on a distinguished road
The Opening BC in CFX is also a pressure outlet BC. Only difference is that it allows a reversed flow and does not close off faces which encounter a reversed flow (like the pressure outlet BC does in CFX)
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   May 11, 2012, 06:18
Elias Paez
Thanks Luke,
And, do you know if it exist a big difference between use pressure inlet or pressure outlet in this case?, because i saw people in the forum using pressure inlet, and i think it is not a good solution.
Old   May 11, 2012, 06:46
In which case? What are you trying to analyse?
In most cases a pressure inlet with a pressure outlet is the most stable BC combo
Regards
Luke
Boundary condition clarification shaswat CFX 1 April 8, 2012 04:06
Fluent Boundary Condition for Opening rippert42 FLUENT 11 November 9, 2011 12:06
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
CFX Solver : Sudden crash Hervé CFX 2 June 16, 2008 06:40
boundary condition set for opening Hellen Main CFD Forum 7 June 29, 2005 09:21
