April 12, 2009, 16:53 |
CHT Boundary Conditions in FLUENT
Saravanan
I am designing a coolant flow inside a solid domain.
I have a rectangular 3d fluid domain inside a solid domain. I have created the geometry in the GAMBIT and imported the mesh into fluent. It created two walls: one wall and one shadow wall for each of the four faces of the fluid domain.i.e bottom wall, bottom wall shadow, top wall, top wall shadow, left wall, left wall shadow, right wall and right wall shadow. What Bc's I have to define on these walls? |
May 14, 2012, 06:13 |
Question on CHT flow in using Fluent
James Willie
Rep Power: 17 |
I just read your post and wanted to know if we have a good tutorial in Fluent for CHT flow simulations? It would be nice if you can give me some citations. I am looking at cooling and would need to do CHT flow simulations for air through a domain and to look at the heat transfer between the air and solid housing of the machine. Thanks in advance for ur input. Jimmy |
May 14, 2012, 06:37 |
Daniel Tanner
Rep Power: 17 |
Walls should be walls and shadows should be set to interior (these are the interface elements between different mesh volumes, e.g., prism to tetrahedral). This can be set in the boundary condition panel in fluent.
May 14, 2012, 07:44 |
Citations of tutorials for CHT flow in Fluent
James Willie
Rep Power: 17 |
Hi Dan,
And thanks for writing. I wanted citations on good tutorials that handle CHT flow in Fluent? I would be grateful if you can give me some references. Thanks! Jimmy |
May 15, 2012, 01:24 |
Rep Power: 17 |
You're wrong there Daniel, wall shadows ARE NOT interiors. Fluent creates a shadow to a wall when there is a cell zone on both sides of the wall. Whatever BC u define for the wall should be defined for the shadow.
For CHT, define your wall and shadow as "Coupled walls" Regards Luke |
Boundary conditions in Fluent. | Novice | FLUENT | 5 | March 20, 2016 11:10 |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 07:15 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
