May 15, 2012, 09:20 |
Pressure Inlet Boundary Condition Issue
Zoe Burton
I am using Fluent to simulate the flow structure in a steam turbine exhaust hood, but am struggling to achieve convergence when I drop the outlet pressure sufficiently to raise the mass flow rate to the 86kg/s I require. I believe the problem lies with the unusual contours I am finding at the pressure inlet boundary - but I do not fully understand how Fluent applies conditions at the boundary (despite reading the manual) to diagnose the problem.
At my pressure inlet plane I have applied representatively profiles of total temperature (absolute as my Operating Condition = 0), total temperature and axial, radial and tangential velocity using the cylindrical coordinate system. The initial/supersonic gauge pressure was lowered to 9362Pa as the inlet flow became supersonic (due to instant divergence from what was originally a stable solution). At pressure outlet boundary plane the static pressure is determined by trial and improvement to achieve the desired mass flow rate, initially set at 9900Pa to give a subsonic flow for the early stages of the calculation. The fluid is set as water vapor, and density as an ideal gas. I am using a pressure based solver and discretization is all 2nd order. After divergence issues, the pressure-velocity coupling was changed from SIMPLE to coupled, which enable me to drop the outlet pressure to 9300Pa and raise the mass flow rate to the desired 86kg/s. However, the solution is unstable, with residuals oscillating (see attached figure) when I drop the outlet pressure after 5250 iterations. I believe this stems from the supersonic flow at inlet (see attached figures). The total pressure profile, is accurate to what I applied at inlet. I would expect supersonic flow on the underside of the inlet plane, but I don't understand the static pressure contour, and how this relate to the mach number contours. I suspect this all stems from my lack of understanding of the pressure inlet boundary condition - can anyone suggest any ideas of where this might source from? I can obviously provide more information, if needed. Any help would be GREATLY appreciated. This has been many many week's work and I have hit a dead end. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
Boundary Condition pressure inlet/oulet for combustion simulations | Giuki | FLUENT | 0 | May 6, 2009 10:04 |
Pressure Boundary Condition | Matt Umbel | Main CFD Forum | 0 | January 11, 2002 10:06 |
