Multiphase flow!
Old   May 14, 2007, 16:31
Default Multiphase flow!
Amer
Hey, I'm doing a study on cavitation around a propeller using fluent and I'm trying to use a multiphase flow (water liquid and water vapor). I checked fluent's tutorials about cavitation and they said that I should have two inlets (Inlet 1 as liquid and Inlet 2 as vapor) but in Gambit when I defined Inlet 1 and Inlet 2 on the same inlet face boundary, fluent wasn't able to see both inlets and it shows only 1 inlet... what should I do to define a multiphase flow??
Please help!
Old   May 15, 2007, 04:16
Default Re: Multiphase flow!
mateus
Hi!
I don't think you have to define liquid and vapor inlet for cavitation simulation... Cavitation in Fluent can be a problem but in latest versions it work fine if you know a few tricks. I did most of simulations in Fluent 6.1 and unsteady. If you want some papers where I described what I did you can send me an e-mail. There was also a article about my work in Fluent-News (fall 2004 issue - I'm not sure).
By MATEUS
Old   May 16, 2012, 15:57
Default help
david
davidmurphy26 is on a distinguished road
hi
i'm working on the marine propeller together with sheet cavitation and of coure hase some problem to capture it correctly, please send me your investigates for seting up FLUENT and your advises(davidmurphy26@ymail.com)
sincerly your
david
Originally Posted by mateus
;141595
Hi!
By MATEUS
davidmurphy26 is offline   Reply With Quote
Multiphase flow information amir FLUENT 2 May 25, 2007 06:01
Realizable k-epsilon eqns for multiphase flow Rana FLUENT 0 December 8, 2006 13:46
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
Multiphase Flow mbga8ejf CFX 0 July 10, 2003 10:26
multiphase flow Shane Gillis FLUENT 10 August 28, 2000 19:12
