Reverse flow warning and solution divergence
Old   May 27, 2012, 15:26
Question Reverse flow warning and solution divergence
Soroush
SH_P is on a distinguished road
I am simulating a steady laminar flow in a geometry very similar to a annular flow (flow between two concentric cylinders). My boundary conditions are velocity inlet and pressure outlet.
As the simulation goes on, Fluent warns about reverse flow in a number of faces on the pressure outlet zone, and the number of faces with this problem increases. The solution converges at firts but eventually begins to diverge as seen in the figure (around iteration 260).
Actually I don't know what does Fluent mean by reverse flow. When I check the velocity vectors at any point during the simulation, they are all pointed outside of my domain on the pressure outlet zone.
Please help,
Thanks
SH_P is offline   Reply With Quote
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
Combustion in ICE - Weller model roadracer Siemens 1 July 22, 2009 04:54
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
FoamX warning SOLUTION msrinath80 OpenFOAM Pre-Processing 0 July 11, 2006 13:29
