June 7, 2012, 06:23 |
domain length
hamid
Hi
How much long should be the length of a pipe with velicity inlet/pressure outlet bc? what about pressure inlet/pressure outlet, please also consider a body inside the domain Thank you Hamid |
June 7, 2012, 06:58 |
If you're asking about the extensions at inlet and outlet then generally use 5D for the inlet extension and 10D for the outlet extension, irrespective of your BC's
Regards Luke |
June 7, 2012, 07:26 |
hamid
Thanks for reply,
why these extensions should be added? what if the downstream regime dosnt show any change even after 2D ? |
June 7, 2012, 08:47 |
The inlet extension is required so that a fully developed flow enters your pipe domain.
The outlet extension is required to avoid reversed flow at the outlet BC. You can start with smaller extensions and then increase if the above criteria are not met. Regards Luke |
June 9, 2012, 04:38 |
hamid
thanks for reply
Interface between fluid domain and porous domain | windhair | CFX | 6 | May 10, 2018 14:26 |
Turbulence length scale and integral length scale | rizhang | CFX | 2 | April 22, 2016 07:22 |
Domain format problem on airfoil flow simulation | andrenonaka | CFX | 14 | December 7, 2015 00:42 |
Solver error message!!! | IoSa | CFX | 1 | September 14, 2006 04:48 |
