June 22, 2012, 07:19 |
user-defined turbulence model
Santo
Can anyone help me how to implement user-defined turbulence mode.
For example I dont have V2F model in my Fluent. So could anyone help me how to implement V2F model in Fluent using user-defined. I was trying last one month...Many thanks in advance.. |
June 25, 2012, 04:15 |
Flavio
hello,
you can use the v2f model through TUI Best regards |
June 25, 2012, 05:22 |
Santo
Sir, Thank you very much for your reply.
I have seen the commands define/models/viscous/user-defined/ after this, Could you explain how to give the damping functions etc... |
June 25, 2012, 05:36 |
Santo
No. there are plenty of low-re-turbulence models available. Howver In fluent only 6 low-re-turbulence model is available. If I want to use user-defined low-re-turbulence model. Then how to use that model in Fluent.
Flavio
in my version of Fluent (v.13) the v2f model already exists (with the command define/models/viscous/user-defined/v2f? yes)
If you have a previous version I don't know how set-up it by UDF... |
June 25, 2012, 06:01 |
Santo
I am using same version Ansys-Fluent 13, when i enter the below lines are coming.. /define/models/viscous> user-defined Viscous user-defined functions: ("none") Enter turbulent viscosity function ["none"] Enter TKE Prandtl number function ["none"] Enter TDR Prandtl number function ["none"] Enter Energy Prandtl number function ["none"] Enter Wall Prandtl number function ["none"] |
June 25, 2012, 06:36 |
Flavio
sorry, I made a mistake
the command is define/models/viscous/v2f? |
June 25, 2012, 08:53 |
Santo
Ok. I dont have this option in viscous. In help it was mentioned that
user-defined-transition/v2f can be enable. But I dont have user-defined-transition |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 21:21 |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 23:43 |
Check particle impaction with User Fortran | Julian K. | CFX | 3 | January 12, 2012 10:46 |
Sato's model of bubble induced turbulence | ukbid | CFX | 0 | January 3, 2011 10:04 |
Fan heater model: what turbulence source to use? | andy20 | Main CFD Forum | 0 | March 2, 2008 13:46 |
