fluent error gui-domain-label: no domain selected Error Object: 1038410352
Like Tree4Likes
  • 1 Post By Fari87
  • 2 Post By sadio
  • 1 Post By dlkadk
Old   August 22, 2017, 08:27
Default fluent error gui-domain-label: no domain selected Error Object: 1038410352
Farhad
Fari87 is on a distinguished road
Hi all,
I'm investigation natural convection on a assembly. I've started a 10s flow-time simulation (time step sizes 0.0015s ~6700 time steps).
The issue regarding the subject of this thread appeared after 6000 time steps (before that the calculation run 3 days without any issues). Plesae also find attached the error message:
"fluent error gui-domain-label: no domain selected Error Object: 1038410352"
Just click "Ok" doesn't work, however after closing that error-window the calculation goes on. But I need to close it after every time step as it appeares regularly...
Does anyone know this issue. Do you have any idea how to solve this problem?
Thanks in advance for your support
Best regards
Fari
Fari87 is offline   Reply With Quote
Old   August 24, 2017, 08:41
Farhad
I still do not know why that error window appeared, however I've solved the problem by downloading a free ware for automated mouse clicks.
It has closed the error message repeatedly, till the calculation was done.
Papes likes this.
Old   October 25, 2017, 19:34
Saheed
sadio is on a distinguished road
Originally Posted by Fari87 View Post
Hi all,
Best regards
Fari
I had same problem just now, but I was able to figure it out. I unchecked Data sampling for time statistics under Run. And it stopped!
I hope it helps.
Arjun kumar P and Papes like this.
sadio is offline   Reply With Quote
Old   May 8, 2019, 04:31
Daniel
dlkadk is on a distinguished road
This can happen when the report definitions are not valid. Please check your report file definitions.
Papes likes this.
dlkadk is offline   Reply With Quote
Old   November 22, 2019, 04:53
Default What is the source of the error?
Sandeep Gosavi
Sandeep_Gosavi is on a distinguished road
I am facing the same issue here. However, I don't want to uncheck the data sampling for time statistics. I checked, rechecked my report definitions as well. Anyone figured this out, what is the reason of this error.
Sandeep_Gosavi is offline   Reply With Quote
Old   October 28, 2020, 02:52
Thumbs up
Vivek MJ
vivjk94 is on a distinguished road
I hope it helps.
Thank you, this works.
Although I had to run the solver for 4 hrs
vivjk94 is offline   Reply With Quote
Old   January 31, 2021, 23:57
Kira
aero_head is on a distinguished road
Creative workaround! Gave me a chuckle, how you just went 'Take that, machine. I'm in control here, give me my simulation results!'
aero_head is offline   Reply With Quote
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 10:54
injection problem Mark New FLUENT 0 August 4, 2013 01:30
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
[ICEM] domain interface in ICEM for fluent hsn ANSYS Meshing & Geometry 24 November 27, 2012 16:43
How to change domain extents in fluent kbs FLUENT 4 April 26, 2008 16:32
