Transient calculation: Change discretization scheme |
August 8, 2012, 03:28 |
Philipp
Rep Power: 26 |
Dear all,
I would like to start each timestep with low order discretization schemes, then switch (after a few iterations) to higher ones in the same timestep for the last few iterations. This should be done automatically for a few thousand timesteps. What am I supposed to do? Thanks for any help! |
August 8, 2012, 10:23 |
For any automation process, you can use journal files which contain TUI commands. In your case, you need a journal file generator which can be a simple program with any language. (refer to manual for more info about journal files) Bests,
Amir |
Generate Workbench-Parameter based on transient Calculation | tim_337 | ANSYS | 0 | November 9, 2011 03:32 |
How to change boundary type at calculation time? | Stanislav Kraev | FLUENT | 0 | December 4, 2006 03:33 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
CONVERGENCE (transient calculation) | mehrnaz | FLUENT | 2 | March 8, 2004 02:55 |
transient calculation | sanjib das sharma | CFX | 2 | July 30, 2001 06:13 |
