Unsteady Combustion
Like Tree1Likes
  • 1 Post By eng_s_sadeghi
Old   July 25, 2012, 18:36
Default Unsteady Combustion
NormalVector's Avatar
NormalVector
NormalVector is on a distinguished road
I'm having a bit of trouble successfully running a hydrogen-air transient combustion case. The basic geometry is a cylinder with a smaller, short concentric cylinder. Oxygen is introduced at the larger cylinder's cross-section while hydrogen is introduced inside of the smaller cylinder and free to flow out. Both are mass flow inlets. I am able to run a steady state simulation and achieve combustion but when I switch over to a transient regime, the mixture never ignites and remains at the species inlet temperature.
I've tried increasing the temperature of both species as to induce ignition but no luck. I've also tried timesteps ranging from 1e-05 to 1e-03 and no luck.
Some solver specifics:
  • Species transport and reactions combustion model (Volumetric, Finite Rate/Eddy Dissipation
  • k-e realizable turbulence model
  • I've used both PISO and SIMPLE pressure-velocity coupling schemes
  • All spatial discretization entries are first order upwind
Any help would be greatly appreciated. As I said, steady state works fine with the same solver settings (if applicable). Switching over to transient results in no ignition.
NormalVector is offline   Reply With Quote
Old   July 25, 2012, 23:05
eng_s_sadeghi's Avatar
eng_s_sadeghi is on a distinguished road
Unsteady combustion is really awful. Please use spark model for ignition on a point and also try to patch a small amount of species (reactants and products) around the point. I always use it.
General80 likes this.
Saeed Sadeghi
Ansys Fluent CFD Consultant
eng_s_sadeghi is offline   Reply With Quote
Old   July 26, 2012, 01:53
NormalVector
Thanks, at least I know I'm not the only one who has had trouble with transient combustion. Is this a known problem in FLUENT? I tried a spark earlier today but that didn't do anything, it was merely an increase in temperature. Are there any spark parameters you recommend (spark energy, diameter, etc)?
Old   July 26, 2012, 03:05
You should increase the spark energy to get a temperature of about 2000K at the point. Also there should be at least a small amount of both reactants and products. Don't forget products should also be around the spark point.
Saeed Sadeghi
Old   July 26, 2012, 16:33
NormalVector
Alright thanks, I'll give it a try.
Old   July 30, 2012, 18:17
NormalVector
Thanks for the help. I was able to get my simulation to combust. Originally, I was using the hydrogen-air mixture template and only included oxygen and hydrogen in the computational domain. When I allowed water to flow into the domain along with the oxygen, the mixture successfully combusted. This was not the case for a steady simulation: the combustion occurred without water present.
Old   April 23, 2014, 04:35
Default fluent spark ignited
qiuyonghai
haibai is on a distinguished road
hi NormalVector,i have met the same problem to use the spark ignited,
I am able to run a steady state simulation and achieve combustion but when I switch over to a transient regime, the mixture never ignites and remains at the species inlet temperature,
i see you have solved the problem,so i am very desired if you could help me
thanks very much
haibai is offline   Reply With Quote
Old   April 23, 2014, 12:52
NormalVector
See my post above, try adding a small amount of products into your domain.
Old   April 23, 2014, 13:26
Smile
qiuyonghai
thanks for your help,i have do it as you said above, rigion a zone around the spark point,and add 0.01productsand some reactants,but it doesnot work,are there other parameters should notice??? desire for your reply
Old   April 23, 2014, 13:58
NormalVector
The only other thing I would suggest is to initialize your entire domain with a small amount of product. That fixed my problem so if that does not work then I don't know what is wrong with your simulation.
Old   April 24, 2014, 03:23
qiuyonghai
thank you i will give it try again
i give the spark energy 2500j and my inlet is 0.05ch4 0.2 o2 ;
i wonder if my inlet boundary conditions set is suited
i am very glad to see you reply
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
Unsteady combustion test case doki Main CFD Forum 0 November 19, 2011 05:15
time step in unsteady combustion process FRANK LEE FLUENT 2 July 25, 2007 04:51
Unsteady combustion Newbie FLUENT 0 July 15, 2003 13:08
unsteady laminar premixed combustion seaspace Main CFD Forum 0 August 5, 2002 23:21
