low Reynolds number problem
Old   August 2, 2012, 04:31
Default low Reynolds number problem
john
johnpaulcd is on a distinguished road
pls anybody could tell me how can i define Reynolds number in a forced convection over 4 planar heat sources placed in line inside a test section of a wind tunnel?
the Re curresponds to flow over a flat plate is very low. but its not getting converged in laminar model of FLUENT.
johnpaulcd is offline   Reply With Quote
Old   August 2, 2012, 05:21
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The characteristic length for the flow over blunt bodies is usually the width of the body.
flotus1 is offline   Reply With Quote
Old   August 7, 2012, 12:55
john
the heat source is similar to flat plate. but 4 such heat sources are arranged in tandem with a gap of 10 mm between them. so can i consider its total length or length of single heat source for defining the Reynolds number?
Old   August 8, 2012, 03:01
flotus1's Avatar
Alex
Why is it so important to define a Reynolds number for this case?
For complex flows, the choice of a characteristic length is quite arbitrary.
Low Reynolds Number SST Model Josh CFX 41 June 4, 2023 19:00
plotting drag coefficient in low reynolds number flow past cylinder atmcfd FLUENT 0 January 2, 2010 08:34
Low Reynolds number airfoil. Pablo Cornejo FLUENT 14 October 19, 2005 09:41
About low Reynolds number airfoil experiment data. zqnwpu Main CFD Forum 5 December 25, 2004 03:52
