August 31, 2012, 04:27 |
Back flow problem in gas cyclone
Rep Power: 15 |
Hi.
I'm working on Stairmand high efficiency cyclone model. I have a problem that I am getting back flow in the central region, from vortex finder. I am using unsteady RSM model with standard wall function (I have also tried the enhanced wall treatment option); with velocity inlet for inlet, outflow for flow outlet, and walls for dustbin and other walls as the Boundary Conditions. For pressure-velocity coupling I am using SIMPLE (I have also used SIMPLEC). For others it is PRESTO, QUICK, 2nd order, 2nd order. For RSM it is 1st order. I'm using Fluent v14, and I have meshed using GAMBIT as well as ICEM CFD, but I am getting the same results. The tangential velocity profile is fine. My problem is the back flow at the outlet (vortex finder). I am still struggling with single phase flow (no Discrete Phase Model introduced yet). Can anybody please help me to get rid out of it. I have also tried to extended the outlet (vortex finder) length upto 5 times the diameter so that the flow is fully developed and there is no back flow, but still the results are same. Do I need to work on some coding (in the form of .udf) to eliminate this? I am stuck to this problem since last 3 months. Looking forward for your positive response. |
Boundary condition problem for open channel flow | Andy | CFX | 9 | June 11, 2016 07:20 |
Multiphase phase (gas-solid) flow using Eulerian-Granular medel ( divergence problem) | jessie | FLUENT | 3 | May 29, 2014 11:05 |
gas solid flow problem validation | pandaba | FLUENT | 0 | October 27, 2010 06:05 |
source term in a gas mixture problem | Kevin | Siemens | 0 | March 27, 2008 05:55 |
cyclone problem | Jichun | FLUENT | 4 | May 16, 2002 04:43 |
